I don't know how to shoot the bullets in different directions. Every time I shoot the bullet follow the direction of the player, but if it turns the bullet stop and turn itself, following the character direction, and when it is still, the bullet just appear but does not move.
Sinistra is the boolean to know if the character is going left, Destra is the identifier for the right.
var Bulli:Array = new Array();
var ShootTimer:Timer = new Timer(0);
stage.addEventListener(MouseEvent.MOUSE_DOWN, startShootTimer);
stage.addEventListener(MouseEvent.MOUSE_UP, stopShootTimer);
ShootTimer.addEventListener(TimerEvent.TIMER, shootBullo);
stage.addEventListener(Event.ENTER_FRAME, mainLoop);
function startShootTimer(e:MouseEvent):void
ShootTimer.start();
function stopShootTimer(e:MouseEvent):void
ShootTimer.stop();
function shootBullo(e:TimerEvent):void
var bullo:Bullo = new Bullo();
bullo.x = Jumbo.x;
bullo.y = Jumbo.y - 50;
addChild(bullo);
Bulli.push(bullo);
function mainLoop (e:Event):void
for (var b:int = 0; b < Bulli.length; b++)
if (destra == true)
Bulli.x += 10;
if (sinistra == true)
Bulli.x -= 10;
add a direction property to each bullo:
function shootBullo(e:TimerEvent):void {
bullo.x = Jumbo.x;
if(something){ // use the appropriate criteria
bullo.dir=destra
} else {
bullo.dir=sinistra
addChild(bullo);
Bulli.push(bullo);
function mainLoop (e:Event):void {
for (var b:int = 0; b < Bulli.length; b++) {
if (Bulli.dir==destra) {
Bulli.x += 10;
} else {
Bulli.x -= 10;
p.s. you should also check when your bullo's are off-stage
and can be removed from the display list and Bulli.
and you should reverse-loop through Bulli
[moved from Adobe Animate CC to ActionScript 3]
Thank you for your answer, but i can't figure out what should go in that IF statement
how did you define destra and sinistra?
var destra: Boolean = false;
var sinistra: Boolean = false;
var v = 5;
function muovi(event:Event)
if(destra == true)
Jumbo.x += v;
Jumbo.gotoAndStop(3);
Jumbo.x -= v;
Jumbo.gotoAndStop(4);
function premi(event:KeyboardEvent):void
switch (event.keyCode)
case Keyboard.RIGHT:
destra = true;
break;
case Keyboard.LEFT:
sinistra = true;
break;
function rilascia(event:KeyboardEvent):void
destra = false;
break;
case Keyboard.LEFT:
sinistra = false;
break;
use:
if(destra){
bullo.dir=destra
} else {
bullo.dir=sinistra
Works like before. The problem is that each bullo follows the character direction
show your mainLoop function
Now it shoots correctly, but if the character goes left and then right all the bullo's change direction.
if (Bulli.dir == destra)
Bulli.x += 10;
else
Bulli.x -= 10;
Nevermind, I worked that out. Thank you for your help!
you're welcome.
(p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
