Hi. when i try to play back my 4k video in ae, the preview is black. when i scrub threw it, I can see it perfectly. when i play it, i can only hear the audio. please help. ae cc 2018.
Here is my system info:
OS Name Microsoft Windows 10 Home
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name LAPTOP-H32O60IK
System Manufacturer HP
System Model HP Laptop 15-bs0xx
System Type x64-based PC
System SKU 1TJ82UA#ABA
Processor Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz, 2701 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date Insyde F.24, 9/25/2017
SMBIOS Version 3.0
Embedded Controller Version 23.40
BIOS Mode UEFI
BaseBoard Manufacturer HP
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.17134.285"
User Name LAPTOP-H32O60IK\paral
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.92 GB
Available Physical Memory 3.95 GB
Total Virtual Memory 9.23 GB
Available Virtual Memory 5.06 GB
Page File Space 1.31 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
please help
Set the Composition Panel Magnification Ratio (bottom left) to 50% or less and comp panel resolution to Auto. That should give you the same playback performance as HD. You might even want to have the Magnification Ratio set to 25%. I have never found a good reason to have comp panel resolution set to anything but Auto.
If that doesn't fix the problem it could be a GPU driver issue or a codec issue.
can you send me a screenshot of where the Composition Panel Magnification Ratio is? I couldnt find it
Start here: Basic AE
Take a close look at the UI and hover over the icons. You will never learn AE unless you spend some serious time studying the manual and looking at tutorials by folks that really know what they are doing. About half of the AE how-to videos on YouTube are pretty useless attempts by amateurs to explain how they managed to get something cool done. Vet your trainers, use the Search Help field at the top right corner of AE (not the help menu), and you'll be ok.
can you send me a picture of where it is?
nevermind. it's set to 12.5 and still not working
The screen shows black, no audio, simply nothing plays. The store works. I have done exactly nothing today other than download two movies so I have zero explanation.
I'm on the latest ITunes version.
I'll be travelling for a few weeks and be off a proper WiFi connection and this is annoying me to no end. Anyone else have had this issue? What can I do to resolve it essentially in the next 7 hours? I'm desperate
Obviously I googled but none of what I found worked.
The audio works on mine. Sorry about that mazenn25. It's super annoying.
Is anyone still reading this?
