8 Replies Latest reply on Sep 16, 2018 7:01 AM by jonathani76621527
    MP4 will play sound but no video in Adobe Premiere Pro CC 2018
    jonathani76621527 Level 1
      Hey All,
      I am constantly editing videos for work but over the past week all of a sudden when I import an MP4 into Adobe Premiere Pro CC 2018 I am only able to hear the audio but can not see the video any longer.  Anybody else have this issue?  I have uninstalled and reinstalled the program, I have even reinstalled earlier versions with the same results.  Any help would be great.  I have attached an image showing the MP4 File but no image showing.2018-09-14_19-20-34.png
        • 1. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
          What is the origin of this mp4.
          Post screenshot of clip in Mediainfo in treeview
          MediaInfo
          • 2. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
            juanmario Level 4
            You lack the program monitor and probably also the origin, you must have windows 10, or I'm wrong ?.
            You will not fix it by installing and uninstalling the program.
            Press the windos + X key, device manager, screen adapters, and uninstall the graphics drivers, then reboot the PC, windows have to reinstall them, in case you do not, you do it manually, and tell us if you fix , or not.
            • 4. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
              Also, yes I have Windows 10... this is a brand new issue.  The last video I was able to complete was on Wednesday.  Not sure if Windows did an update or not.
              • 5. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
                You need to run the file through Handbrake and make it Constant Framerate, then bring it into Premiere.
                HandBrake
                • 6. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
                  Will I need to do this for all videos?  Here is a video I was just able to complete rather recently but now it will not display at all.
                  General
                  Complete name                            : C:\Users\jimpe\Dropbox (Fantasy Alarm)\Brandon Marianne Lee\Deep Cuts\9.8.18 Deep Cuts.mp4
                  Format                                   : MPEG-4
                  Format profile                           : Base Media / Version 2
                  Codec ID                                 : mp42 (mp41/mp42/isom)
                  File size                                : 232 MiB
                  Duration                                 : 3 min 55 s
                  Overall bit rate mode                    : Variable
                  Overall bit rate                         : 8 260 kb/s
                  Movie name                               : 9.8.18 Deep Cuts
                  Movie_More                               : This video is about My Movie 124
                  Encoded date                             : UTC 2018-09-08 16:06:03
                  Tagged date                              : UTC 2018-09-08 16:06:45
                  thmb                                     : ÿØÿà
                  Video
                  Format                                   : AVC
                  Format/Info                              : Advanced Video Codec
                  Format profile                           : High@L3.1
                  Format settings                          : CABAC / 2 Ref Frames
                  Format settings, CABAC                   : Yes
                  Format settings, RefFrames               : 2 frames
                  Format settings, GOP                     : M=1, N=30
                  Codec ID                                 : avc1
                  Codec ID/Info                            : Advanced Video Coding
                  Bit rate mode                            : Variable
                  Bit rate                                 : 8 004 kb/s
                  Maximum bit rate                         : 768 kb/s
                  Width                                    : 1 280 pixels
                  Height                                   : 720 pixels
                  Display aspect ratio                     : 16:9
                  Frame rate mode                          : Constant
                  Frame rate                               : 29.970 (30000/1001) FPS
                  Color space                              : YUV
                  Chroma subsampling                       : 4:2:0
                  Bit depth                                : 8 bits
                  Scan type                                : Progressive
                  Bits/(Pixel*Frame)                       : 0.290
                  Stream size                              : 224 MiB (97%)
                  Title                                    : Core Media Video
                  Color range                              : Limited
                  Color primaries                          : BT.709
                  Transfer characteristics                 : BT.709
                  Matrix coefficients                      : BT.709
                  Codec configuration box                  : avcC
                  Audio
                  Format                                   : AAC LC
                  Format/Info                              : Advanced Audio Codec Low Complexity
                  Codec ID                                 : mp4a-40-2
                  • 7. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
                    This one looks fine. The first one had a wide range in framerate.
                    Update your videodriver.
                    • 8. Re: MP4 will play sound but no video in Adobe Premiere Pro CC 2018
                      Ok but when I upload the video into Premiere it I have the same issues. Neither video will appear just the audio
