7 Replies Latest reply on Feb 8, 2008 11:13 PM by BKBK
    CFLOCK and session vars
    emadsen
      I am building a multiuser site with session vars. I understand the need for exclusive locking when writing session vars, but am a little confused when it comes to reading them. I have the need to use certain session vars within SQL queries, etc. I do need to use exclusive here as well, right? Also, Is this bad?
      I'd rather not have a hundred cflock statements within my CFC functions, etc.
        • 1. Re: CFLOCK and session vars
          Level 7
          Which CF version?
          One hasn't had to - intrinsically - do this since CF5.
          Read the docs regarding when to lock shared-scope data:
          http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=sharedVars_20.html
          > Also, Is this
          > bad? <cflock scope='session' timeout='30' type='exclusive'> <cfset mySess =
          > session /> </cflock>
          This will achieve little, as it will simply create a reference to the
          session scaope, rather than a copy. All you're doing is referring to the
          same shared-scope data (with the same potential issues) via a different
          variable name.
          On the whole, locking shared-scope data is far less of a concern since CF5
          than it used to be.
          If you want to do some reading, read the doc I pointed you to, and Google
          CFLOCK. This conversation has been well documented several times in the
          past (and at least ocne on these forums within the last month or so).
          Adam
          • 2. Re: CFLOCK and session vars
            emadsen Level 1
            This cannot be true. I am using CF8. Without an exclusive lock on both reading and writing my application's session variables I have witnessed my users getting their sessions mixed up.
            Example: My users (average of 150 concurrent) all get content generated from a single SQL view, and we pass in their userId using cfqueryparam. If I do not wrap that query in an exclusive session lock, users randomly see results that are not meant for their eyes.
            • 3. Re: CFLOCK and session vars
              Dinghus Level 1
              That sounds like a problem with the variable scoping.
              • 4. Re: CFLOCK and session vars
                Level 7
                Session variables aren't shared *between users*. They're specific to a
                user. The only time you're going to be getting contension with a session
                variable is when a single user has two browser windows open hitting the
                same site. If you've got some weird session bleeding between different
                users, then <locking the session scope isn't going to help.
                You're problem is something else, and your locking strategy is at best
                dealing with it coincidentally. Which should be a bit of a concern...
                Adam
                • 5. Re: CFLOCK and session vars
                  Level 7
                  > contension
                  Oh dear.
                  "contention".
                  Adam
                  • 6. Re: CFLOCK and session vars
                    Level 7
                    > You're
                    Groan. I give up.
                    Adam
                    • 7. CFLOCK and session vars
                      BKBK Adobe Community Professional & MVP
                      The answer might simply be to rename a variable into session.someResult. In fact, you could even do this:
                      <cfquery name="session.getOrderItem">
