I am trying to deploy a CF 11 .car file on CF 18.
In the admin, I can browse to the .car file, select it, and click deploy. The screen refreshes but none of the data sources get added? Does CF 18 allow CF 11 .car files?
It should allow those. Are the other things happening? The CAR deployment UI has always been kind of clunky, and sometimes the buttons you need to push are not that intuitive - at least, for me.
Dave Watts, Fig Leaf Software
Yes, ColdFusion 2018 supports CAR package deployment. Did you select the Data source while creating the CAR package?
Vikram
Brendan, I would check the CF11 CAR file. I was able to import mine into a test CF2018 with some issues but the DataSources did come over. Might be something not selected within the CF11 CAR export from its CFAdmin...
Adding to what others have said, look at the migration logs in the CF2018 instance's logs folder. There will be two of them. Perhaps they will explain what is amiss. If there are none, then the migration is not happening, and in that case look at the other CF logs at that time to see if there's any explanation.
BTW, it sounds like you are getting the first popup (to select the file), so perhaps this is not an issue, but in many browsers popups are blocked, and you need to choose an icon in the top right to tell it to allow them for the site in which you are loading the CF admin. that often stumps people using the CAR feature, as it does rely on popup windows.
Thank you very much! I had same issue and did not notice that a pop-up was being blocked.
