3 Replies Latest reply on Feb 6, 2008 4:33 AM by tomellos
    Drag a movie according to a circle
    auit
      Hi there,
      I'm a newbie with Flash and I have a question, please help me !
      I have to make a clock which has 2 buttons: start and end. And user can control 2 buttons to get the start time and end time they want. I wrote this code to make the buttons can be draged and droped but I don't know how to let the buttons to be draged according to a circle of the clock.
      Please answer me as soon as you can because it's quite urgent.
      Thanks so much
      Thu.
        • 1. Re: Drag a movie according to a circle
          Level 7
          auit,
          > help me !
          That's what the forums are for. :)
          Okay.
          Aha. Well, the startDrag() function, and its MovieClip.startDrag()
          method, don't much care *where* you drag a movie clip, only *that* you drag
          it. Actually, both the function and the method do allow you to constrain to
          a rectangle (see the optional parameters for either).
          > quite urgent.
          Heh, I'm sure everyone who posts a question believes it to be urgent.
          ;) Let's see what we can do, here. It just happens that I recently blogged
          about how to constrain to a circle. I'm not sure your need is to constrain,
          per se -- it sounds as if you want to drag your movie clip on the edge of a
          circle only -- but if you piece through my sample code, you'll see that the
          answer to what you're after can be derived from the information presented.
          http://www.quip.net/blog/2006/flash/actionscript-20/how-to-constrain-circle
          Hint: you'll want to forego the if() statement and simply use the part
          that sets the MovieClip._x and MovieClip._y properties to the mouse's
          position.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Drag a movie according to a circle
            Level 7
            auit,
            > It just happens that I recently blogged about how to constrain
            > to a circle. I'm not sure your need is to constrain, per se --
            > of a circle only -- but if you piece through my sample code,
            > you'll see that the answer to what you're after can be derived
            Well, on second thought, the difference is probably too greate between
            what you want and what that other article illustrates. I wrote a new blog
            entry to handle your clock hand dragging. Check it out here. :)
            http://www.quip.net/blog/2006/flash/actionscript-20/how-to-drag-clock-hands
            David Stiller
            • 3. Re: Drag a movie according to a circle
              tomellos
              Needed this code and I found thanks to this forum and your good explanation. Also your blog is in my favourites from now.
              Thanks for share.
              Tomelloso
