Hello, how to render high quality audio/music for YouTube ?
Example : https://www.youtube.com/watch?v=4D7u5KF7SP8
How to reproduce this quality ?
i've try a lot of codec and format
Please help me ! thank you
Si tu audio es de baja o mediana calidad no esperes tener una calidad optima. Aun asi te sugiero que uses el siguiente setting:
If your audio is of low or medium quality do not expect to have an optimal quality. Even so, I suggest you use the setting in the picture:
I recommend exporting Cineform YUV 10 bit for YouTube (under QuickTime format). YT will accept the files, and the quality is the best that PP can create.
I think you're right, but I also think that youtube uses a private tool
