Hello,
we are trying to install Acrobat Pro via Adobe Customization Wizard on a Terminalserver environment. Installation works fine, however we have some users which use the German language pack, and others using English. I'm trying to achieve Acrobat to ask users, for the first time they start the client, which language they would prefer. Currently it always selects German as default, since this is our system language.
Is there any solution for this via Customization Wizard or registry, to force Acrobat displaying the language selection popup?
I would appreciate any help.
Kind regards,
Morris
I finally found a working solution. First I was using a script (RegUpdateAllUsers/RegUpdateAllHkcuHkcr at master · micksmix/RegUpdateAllUsers · GitHub) which iterates trough all users available on a machine. In my case I have edited the script, so it creates the key mentioned in my previous post for every users hkey_current_user entry. As a result of this, the language popup appears for every >existing< user.
Sadly I have encountered problems concerning my logon script. It works perfectly on Wind
...Copy link to clipboard
Moving this query to the correct community Installing, Updating, & Subscribing to Acrobat .
Hi Morris,
As per the issue description mentioned above, you want users to select the language for Acrobat DC upon launch, is that correct?
You may check the language selection option upon Acrobat's launch by pressing Ctrl when launching Acrobat, This will asks users to select the language for Acrobat. Refer to this forum thread for more info: How to change application language in Acrobat Pro DC?
You may also check language option under Acrobat's preferences by clicking Edit > Preferences > Language > Application language > choose at application startup.
You can also check the customization wizard's installation option here: Language Support and Configuration — Enterprise Administration Guide
Preference Reference for Acrobat and Adobe Reader
Shivam
Hi Shivam,
thank you for your response. I already knew the trick concerning pressing Crtl, when launching Acrobat. However this does not solve my problem, since I cannot expect users to know about this option.
Same is true concerning the preferences settings. English users of course won't be able to change the language since they cannot read a german menu structure.
Sadly I can also not find a proper solution within the customization wizard. I wonder why there is no option like "let user select language at first startup".
I have tried to come across this issue and created a script which will be executed only the first time a user logs on to the terminal server (no local profile available on the machine). It creates a registy key called "select" under: HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\2017\Language". This item obviously forces Acrobat to ask which language to select. After selecting a language, the entry will disappear (which is the reason, why the script runs only once). This solves my issue for new users. Nevertheless it's still a problem for existing once, since i would need to update all "Current_User" keys on the machine.
Kind regards,
Morris
Sadly I have encountered problems concerning my logon script. It works perfectly on Windows 7 Machines, but not on a terminal server. I have bypassed the problem by editing the NTUSER.DAT (regedit --> load hive) of the default user, and manually added the key. Thus the key is created as soon as a new user logs on for the first time.
Since the key is automatically deleted after the popup was answered, the user want be asked again.
