3 Replies Latest reply on Jan 12, 2009 5:12 AM by Newsgroup_User
    Upgrade questions
    christinett
      I have an active website using a database and extensions. If I upgrade from MX 2004 to CS3 or CS4, will I lose anything? Will I have to create a new site, reset preferences and settings, re-install extensions, re-establish database connections, etc.? Will the interface be familiar enough that I can carry on what I've been doing without having to immediately learn anything new? I need answers to all these questions before I decide to upgrade...thanks.
        • 1. Re: Upgrade questions
          Level 7
          You shouldn't.
          > database
          > connections, etc.?
          If you upgrade to CS4, you will have to re-activate your extensions. But
          they will already be migrated into Extension Manager for you to do this.
          Although the UI is different, it's basically similar. You should be fine.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "christinett" <webforumsuser@macromedia.com> wrote in message
          news:gkdksk$t20$1@forums.macromedia.com...
          >from MX
          > site,
          > database
          > on
          > need
          • 2. Re: Upgrade questions
            Level 7
            There was a change in the server behaviours code in Dreamweaver 8.02
            that prevented SQL injection hacking attempts. All recordsets and server
            behaviours need to be reapplied.
            http://www.adobe.com/support/security/bulletins/apsb06-07.html
            Dooza
            • 3. Re: Upgrade questions
              Level 7
              Also, whilst you won't need to reinstall your extensions, you might need
              the newer versions, as many weren't compatible with CS3, some are still
              be rewritten for CS4, so you need to check with the author of all your
              extensions before enabling them after the upgrade.
              Dooza
