5 Replies Latest reply on Oct 14, 2018 6:20 AM by Colin Flashman
    Pages to Layers Script
    ixladxi
      Hello,
      Background: The job I'm working on was created using datamerge. Its a postcard that has a common master page background. I merged in an address and map.
      As expected I now have over 200 pages of postcards with the merged background, address, and map. I need to export them into separate files that have individual names. So what I would like to do is somehow move the pages into layers on a single page and name the layers the file names I need, then export them using the script, "PageExporterUtility". For those not familiar PageExporter lets you choose a base layer and variable data layers on top and creates and individual file for each using the name of that layer.
      The problem I'm running into is that I can't find a way to move all of the pages into layers on one page.  I found was able to make each page it's own layer but it stays on that page. Here's my script so far below.
      Thanks for your help.
      Jeff
      for(var p=0; p<document.pages.length; p++)
          var myPageItems = document.pages[p].pageItems.everyItem().getElements();
          var myLayerPage = (p+1);
          for(var i=0;i<myPageItems.length;i++)
              try{var myLayer = app.activeDocument.layers.add ({name: "Page " + myLayerPage});}catch(e){}
              myPageItems[i].itemLayer = "Page " + myLayerPage;
        • 1. Re: Pages to Layers Script
          ixladxi Level 1
          I guess I should mention that this is for 2018 CC.
          • 2. Re: Pages to Layers Script
            Benreyn Level 1
            Hi ixladxi,
            You were very close... I used your script above and edited as such, notice the last part (added var doc for my script execution purposes):
            var doc = app.activeDocument;
            for(var p=0; p<document.pages.length; p++)  {
                for(var i=0; i < myPageItems.length; i++) {
                    try {
                    } catch(e) {}
            var myPage = doc.pages.add();
            for(var x = 0; x < doc.layers.length; x++) {
                doc.layers[x].pageItems.everyItem().duplicate(myPage);
            It will add a page at the end of the document and duplicate all the created layers to it.
            Hope that helps.
            • 3. Re: Pages to Layers Script
              ixladxi Level 1
              Thank you so much! This worked. It combines it all on the last page.
              • 4. Re: Pages to Layers Script
                RichardChenoweth
                Benreyn This works very well! I have some before and after steps that I would like to add in order to automate a portion of my workflow. I'm more familiar with AppleScript than .jsx and believe I will need to jump from Excel to BBedit to InDesign to accomplish what I'm envisioning.
                My process will be extracting 2 columns of tabbed data, cleaning spaces & line endings, InDesign Data Merge, this script, and moving the resulting layers to the working document.
                I want to take a shot at doing it myself but would greatly appreciate your thoughts and or warnings if any.
                Thanks!
                • 5. Re: Pages to Layers Script
                  Colin Flashman Adobe Community Professional
                  If you still had access to the original un-merged INDD file, would my Data Merge to Unique Names script be of use? Here's a video of it in action: Episode 1: Data Merge to Unique Names - InDesign Javascript by Colecandoo - YouTube
