Starting suddenly about 2 weeks ago, I can no longer keep Illustrator running for longer than 5-10 minutes. After a few minutes Illustrator starts to glitch out (changing text properties on selected text changes other unrelated text, objects start to randomly move about, cannot select elements, ctrl-z doesn't work, etc.) The program doesn't actually freeze or quit and close, it will stay open but in this unusable state. I have to manually quit then it gives me the 'Adobe Illustrator CC 2018 quit unexpectedly' report. I can reopen and it will work again for 5-10 minutes, then glitches.
I have tried rebooting, uninstall/re-install Illustrator which didn't help. I disabled GPU Performance, also did not help. This is only on Illustrator, all other Adobe CC programs working fine. All other programs on my computer are working fine. I can provide the error report if needed.
2012 Macbook Pro
2.6 GHz i7
16 GB 1600 MHz DDR3
Any help would be greatly appreciated.
Jess,
It sounds as if the Poltergeist Tool has been invoked.
Is it also happening if you have nothing else running? Sometimes, some usual suspects may mob or confuse Illy so she moves in (even more) mysterious ways (than usual).
If no brighter solutions appear, you may try the list below, ending with the serious 6) which may be be relevant.
If things that should work simply refuse to (all possibilities exhausted including the A) - C) below (and carefully making sure you are performing (all) the need
...Copy link to clipboard
Which system is it?
Ah, sorry. It's Mac OS Sierra 10.12.6.
Hi Jess,
I would like to know if the steps suggested by Jacob worked for you?
Kindly update the discussion if you need further assistance with it.
Srishti
Jess,
If things that should work simply refuse to (all possibilities exhausted including the A) - C) below (and carefully making sure you are performing (all) the needed things)), you may try (the relevant part(s) of) the list 1) - 6) below.
Sometimes, (certain) things may fail or stop working for no apparent reason. When the (other) possible reasons/cures fail to work, it may be some kind of (temporay or permanent) corruption, or even some inconvenient preference setting(s), which may be cured with something on the following list set up in an attempt to provide a catchall solution for otherwise unsolvable cases. It starts with a few easy and harmless suggestions 1) and 2) for milder cases, and goes on with two alternative ways 3) and 4) of resetting preferences to the defaults (easily but irreversibly and more laboriously but more thoroughly and also reversibly), then follows a list 5) of various other possibilities, and it ends with a full reinstallation 6). If no other suggestions work, or if no other suggestions appear, you may start on the list and decide how far to go and/or which may be relevant.
The following is a general list of things you may try when
A) The issue is not in a specific file,
B) You have a printer correctly installed, connected, and turned on if it is physical printer (you may use Adobe PDF/Acrobat Distiller as the default printer with no need to have a printer turned on, obviously you will need to specify when you actually need to print on paper), and
C) It is not caused by issues with opening a file from external media.
You may have tried/done some of them already; 1) and 2) are the easy ones for temporary strangenesses, and 3) and 4) are specifically aimed at possibly corrupt/inconvenient preferences); 5) is a list in itself, and 6) is the last resort.
If possible/applicable, you should save current artwork first, of course.
1) Close down Illy and open again;
2) Restart the computer (you may do that up to at least 5 times);
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (easy but irreversible);
4) Move the folder (follow the link with that name) with Illy closed (more tedious but also more thorough and reversible), for CS3 - CC you may find the folder here:
https://helpx.adobe.com/illustrator/kb/preference-file-location-illustrator.html
5) Look through and try out the relevant among the Other options (follow the link with that name, Item 7) is a list of usual suspects among other applications that may disturb and confuse Illy, Item 15) applies to CC, CS6, and maybe CS5);
Even more seriously (this may be serious because you may need to restore plugins and whatnot afterwards if you have customized things), you may:
6) A) Uninstall (ticking the box to delete the preferences if applicable), B) run the Cleaner Tool (if you have CS3/CS4/CS5/CS6/CC), and C) reinstall. You may try without step B), but sometimes it is needed, because otherwise things may linger.
As it appears from this thread, it may be worth repeating this if it fails to help the first time:
https://forums.adobe.com/thread/2283530
To uninstall:
Cleaner Tool:
