3 Replies Latest reply on Feb 4, 2008 10:27 AM by www.hdgreetings.com
    Installed base on h.264 enabled flash players
    Batteram
      Anyone know what the market share currrently is of flash update 3 players (h.264 enabled)?
      And more importantly, if you had everything ready to go, when would you feel comfortable switching over a site to h.264 only?
      Obviously users can be prompted to upgrade but how annoying do you feel it is to users to take that step, vs jut waiting for the market share to naturally get higher for flash update 3?
      thanks for any feedback
        • 1. Re: Installed base on h.264 enabled flash players
          RossRitchey Level 4
          Adobe has a web-page that gives flashPlayer penetration statistics from their tracking.
          http://www.adobe.com/products/player_census/flashplayer/version_penetration.html
          This only gives stats for the major versions, though, not the minor versions. They almost need to give stats for minor versions with player9, considering the major changes that happened between 9,0,47 and 9,0,115.
          Personally, I don't mind getting prompted to update my player. Typically, I have seen companies wait 2 versions before updating, to ensure penetration. Some companies are still publishing to player5 currently, while others have updated to player7, and sometimes 8. Only the cutting edge companies are even publishing to player9 yet.
          The key is to know your audience. If the majority of your audience would be on "the cutting edge" when it comes to technology, then it is likely that they will have already upgraded their flash player to the most current, and will not mind a reminder that they haven't updated yet.
          • 2. Re: Installed base on h.264 enabled flash players
            Rothrock Level 5
            rrittchey is correc, "Know your auddience." For example if your audience is corporate folks a lot of IT departments I know won't update to Flash 9 plug-in until Flash 11 has been out for a while. So that would be quite some time.
            If your audience has control over their own machines and they are motivated to want to see your content then I see no reason why they wouldn't want to upgrade.
            If you are somewhere in the middle, then maybe waiting until the 10 plug-in comes out might make sense.
            • 3. Re: Installed base on h.264 enabled flash players
              www.hdgreetings.com
              Excellent advice, thank you both for your help.
              Btw I was able to ask someone with web google analytics and (for their site anyway) the market share for v115 is about 15% right now.
