• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to add .fm files to existing book using ExtendScript ToolKit
New Here ,
Sep 24, 2018 Sep 24, 2018
I am writing an ExtendScript Toolkit script to open a ditamap, save it as a book, and then add some boilerplate .fm files in a specific order between the title page and TOC.
So far I've got everything except adding the boiler plate .fm files.  Anyone know how to do that?
var sourceDoc = openXmlFile("Ditamap file path goes here");
var path = "Output file path goes here";
saveToFm(sourceDoc, path);
function openXmlFile(filePath) {
    var file = File(filePath);
    var fileName = file.fsName;
    var openParams = GetOpenDefaultParams();
    var retParams = new PropVals();
    var doc = Open(fileName, openParams, retParams);
    return doc;
function saveToFm(fileObject, savePath) {
    var saveParams = GetSaveDefaultParams();
    var i = GetPropIndex(saveParams, Constants.FS_FileType);
    saveParams.propVal.ival = Constants.FV_SaveFmtBookWithFm;
    var i = GetPropIndex(saveParams, Constants.FS_DitavalFile);
    saveParams.propVal.sval = "Dit Val file path goes here"
    var saveAsName = savePath;
    var returnParamsp = new PropVals();
    fileObject.Save(saveAsName, saveParams, returnParamsp);
TOPICS
Scripting
Views
886
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Sep 24, 2018 Sep 24, 2018
Assuming the book is your book object, you can do something like this:
bookComp = book.NewSeriesBookComponent (0);
// Move it to the end.
if (bookComp.NextComponentInBook.ObjectValid()) {
    bookComp.NextComponentInBook = 0;
} // Set its path.
bookComp.Name = "Absolute path to the component.";
Votes
Translate
Translate
Community Expert ,
} // Set its path.
Votes
Translate
Translate
Report
Report
New Here ,
I've updated my code with a
var book = app.ActiveBook;
And your function to add book components
function addBoilerPlate(book, componentPath) {
} // Set its path.
bookComp.Name = componentPath;
bookComp.MoveComponent(1);
By itself your function adds the boilerPlate.fm to the end of the book.  However, I want it between the title and TOC.  Once it is added I can move it up with bookComp.MoveComponent(1); but the final version of this script will deal with books with different numbers of chapters so that wont work.  Is there a way for me to add boilerPlate.fm between 2 specific pages or after or before a specific page?  I tried modifying the 0s in your function, but no matter what I did it always added boilerPlate.fm to the end of the book.
Full code:
var sourceDoc = openXmlFile("Absolute path to ditamap");
var path = "Absolute path to output";
var componentPath = "Absolute path to boilerPlate.fm"
addBoilerPlate(book, componentPath);
    return doc;
    saveParams.propVal.sval = "Absolute path to Dita Val File"
} // Set its path.
Votes
Translate
Translate
Report
Report
Community Expert ,
Find the toc component; let's assume that the variable is tocComp. Then you can do this.
bookComp.NextComponentInBook = tocComp;
Votes
Translate
Translate
Report
Report
New Here ,
Sep 25, 2018 Sep 25, 2018
LATEST
Thank you!  I got it working:
var sourceDoc = openXmlFile("Absolute file path to ditamap");
var path = "Absolute file path to output file";
var boilerPlate_1 = "Absolute file path to BP1"
var boilerPlate_2 = "Absolute file path to BP2"
var tableOfContents = book.FirstComponentInBook
tableOfContents = tableOfContents.NextComponentInBook
addBoilerPlate(book, boilerPlate_1, tableOfContents);
addBoilerPlate(book, boilerPlate_2, tableOfContents);
    return doc;
    saveParams.propVal.sval = "Absolute file path to Dita Val File"
function addBoilerPlate(book, componentPath, tableOfContents) {
var bookComp = book.NewSeriesBookComponent (0);
    bookComp.NextComponentInBook = tableOfContents;
} // Set its path.
Votes
Translate
Translate
Report
Report
