2 Replies Latest reply on Sep 27, 2018 4:28 AM by Laubender
    EPS Transparency
    kelseyl43962324 Level 1
      I was sent an indesign file that I am reformatting and making edits to and there is one object that when exported to PDF is not keeping the transparent background. I think this is because the image was inputted as an EPS image. I don't have the original image. Is there a way for me to have the EPS object maintain transparency or convert the image in a different way without the original image?
        • 1. Re: EPS Transparency
          Are you sure this is a scripting-related question?
          Scripts can only manipulate existing objects and properties. It cannot add an entirely new function to the program.
          • 2. Re: EPS Transparency
            No. There is no way. You need the original EPS graphic file that is placed.
            A mediocre workaround with low or very low quality:
            Do a screenshot of the placed EPS.
            Open the screenshot in PhotoShop and redo transparency.
            Work with the faked result for PDF export.
            Regards,
            Uwe
