4 Replies Latest reply on Nov 13, 2018 9:38 AM by AndyB-LondonSecretAgency
    playback does not work
    jj 2000
      i need some help with my premiere pro. I am not able to playback anything in my program monitor. i have tried everything, from changing the short cut to delete and reinstal to encode my files to a other format. it has been like this for about 2 weeks and before this there has never been any issue with editing my files. I use a dell xps 15 9570, i7 8th gen.
      i hope someone in tis forum can help me out
      cheers!
        • 1. Re: playback does not work
          Richard M Knight Adobe Community Professional & MVP
          Take a look at you Audio hardware setup, there might be an error there that is stopping the playback. Often Windows updates upsets this.
          • 2. Re: playback does not work
            Kevin-Monahan Adobe Employee
            Solved this issue yet, jj%202000? Let us know.
            Kevin
            • 3. Re: playback does not work
              AndyB-LondonSecretAgency Level 1
              BUMP!
              No Playback in PP 2019.  13 Nov 2018.
              Project was working fine this afternoon. Now the spacebar does not work at all in PP2019, the Play Button doesn't work, scrubbing the playhead in audio, source and program doesn't work either.  My producer is livid, but at me!
              Here's what I've tried
              Restarting
              Restarted PP
              Updated PP to most recent
              Empty the Cache
              Move the Cache
              Resetting the workspace
              Changing the renderer
              Restarting Premiere Pro again and again.
              Check that it's not a Mac Spacebar problem (it's not as I'm typing this).Duplicate the Sequence (this sometimes works on other Premiere audio-issue bugs)
              Check the audio output
              Make a new comp
              I'm stumped now. Any advice?
              • 4. Re: playback does not work
                WORKED AROUND - do not use Premiere Pro 2019 just yet.
                Use this lovely tool to go back to 2018 and make edits great again.  This works immediately in 2018!
                Edited By Moderator to remover Link.
                No need to use some 3rd party tool as you can revert to Pr Pro from the Adobe CC DTA.
