Hi folks,
is there any way to make actionscript to accept a self signed certificate
when urlLloader requests to a local server (so on the client side)?
thanks
yes, I read it, and apparently flash is dependent from the browser CA authority.
So the only way is to tell the client to install the CA root first to be able to communicate successfully.
are you creating an air app?
No, embedded swf in website page
there should be restrictions on your swf's access to the user's computer any work-around would be a security issue.
what are you trying to do?
ok so the only solution is to let the user download the cert and install it on his browser?
the client has its own web server in localhost only. and would like my swf
access to his web server in https since the swf is also loaded in https
you should be able to use a cross-domain policy.
I already have on the doc root of the client web server (which is only accessible from the localhost)
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<site-control permitted-cross-domain-policies="all"/>
<allow-http-request-headers-from domain="*" headers="*" secure="false"/>
<allow-access-from domain="*" secure="false"/>
</cross-domain-policy>
should I remove any restriction on the swf side?
ok now http works well, but https connection returns from the server
Connection from 127.0.0.1:27376.
getpeername failed: Transport endpoint is not connected QUITTING
on the swf side:
onSecurityStatus error: Error #2048
does it need a specific certificate?
btw the connection is done with https://127.0.0.1:59999/index.html
you'll need to allow connection from your secure domain. i've not done that before so you'll need to check the documentation for an explanation.
