• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
TipsNTrix
Explorer ,
Feb 07, 2008 Feb 07, 2008
Under adding notes to a topic, you say "Make a hyperlink out of the image. In the Hyperlink dialog, type JavaScript:Shortcut.Click()".
I using v7. In which part of the Hyperlinks Properties dialog do you put this?
Views
653
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Hi harooki2
You type it where you would normally see the path and HTML filename. That big long field at the top of the dialog.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
OK, that's what I thought. I did that.
When I compile, though, I don't see the note icon I'm using for the hyperlink image. However, it works when I have a remote URL in there.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
Perhaps try adding the image file to baggage?
Just a thought... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
Well, that didn't fix it either.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
So you have this as an image on the page? What if you take away any JavaScript or whatever. Do you see the image then after you compile?
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
If I take the hyperlink off, I can see the image after I compile. If I take the shortcut control off and leave the hyperlink on, I can see the image after I compile; but then the hyperlink doesn't work.
This is a slick trick (if I can get it right), and I want to use it.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
Okay, I've been out to lunch and when I came home the cable company had me down for a period of time as they were replacing cable.
Now that I'm back...
What version of RoboHelp are you using? I'll test using that version to see if something got lost in translation since I first created that workaround.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
I'm using v7. Can we post or upload graphics on this forum? If so, I can send you a graphic of my setup.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
Nope. but you can do it over here.
Or if you like, just send what you need me to see via my personal E-Mail. Which is rstone75 (at) kc (dot) rr (dot) com
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
I have to catch a train for home now. I'll catch up with you tomorrow. Thank you so much for taking your time with this.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
