The image below is the existing animation. I'd like to add a checkbox which when enabled, will change the value of the second (and third) keyframe values. I have the 'new value' for when the checkbox is enabled - I'm having issues getting the animation to update with this new value (for the 2nd and 3rd keyframes).
I'm pretty certain I've done this many times before but I'm stumped at the moment. TIA!
Hi Roland,
I think you can do it this way;
checkboxOn=effect("Checkbox Control")("Checkbox")[0];
keyframeValue=15;
k1 = key(1).time;
k2 = key(2).time;
if (time<=k1) value;
else
if (time>k1 & time<k2) ease(time,k1,k2,value,keyframeValue)
else
if (checkboxOn)(keyframeValue)
else
value
Thanks buds! I found another solution/method/strategy BUTT I'll be keeping this aside just in case I need such a solution.
Would love to see what you ended up using?
I actually can't recall which route I went with - there were lots of different Expressions involved in my task and as always lots of walls and hurdles to overcome. I'll be in touch once the product is released - your AE/PPro students may enjoy using it or you can use it to show them what's possible with MoGRTs and Master Props.
I'm back!!! And I suck! LOL
With two keyframes, what you've provided is what I've done previously - using the Linear method. However, my issue is with three or more keyframes.
In short, how do I affect a single keyframe's value when the prop has more than two keyframes?
With more than two keyframes, the Linear method is not viable unless there's some advanced gymnastics involved; which is beyond me at the moment.
I've found a solution which works but I was hoping for a more elegant/script-based solution. FWIW, I simply linked the prop with KFs to a slider which is user-controlled. As long as I limited the value that a user could input, I was able to ensure things look good.
