Hi, I'm a long time user of AE but still somewhat of a novice when it comes to expressions. Anyway, I'm trying to setup presets for the text animations since I do a lot of repetitive work. My question is can you link the dropdown option in text animation/ e.g. Position/ Advanced -> based on (Characters,Words, Lines dropdown) to an expression like a slider control so I don't have to keep digging into it. Since I usually put multiple text animation controls, it's annoying to have to dig into every control to change from Letters to Words or what have you. It'd be great to have it and control multiple drop downs with one control. Also, would be better not to have multiple versions of presets for each type of animation. I'm not sure if this even possible. Thanks.
In general, if a property doesn't have a keyframe stopwatch, you can't apply an expression to that property.
Dan
Dan
Thanks, that's what I figured. Too bad. It could've been a time saver.
Moved from After Effects Scripting​ to After Effects Expressions​
