4 Replies Latest reply on Feb 6, 2008 3:16 PM by eLearningDeveloper
    inspecting unknown objects
      My Flash program loads external swf files not created by me, and I need to access the properties inside them. Iterating through the loaded mc clip:
      for( var item:String in myLoadedClip_mc ) {
      trace( item + " :: " + myLoadedClip_mc.item + "\n" );
      gives a series of propertie names - for "item", however, all values using myLoadedClip_mc are undefined.
      When I use toString() with the code above:
      trace( item + " :: " + toString( myLoadedClip_mc.item ) + "\n" );
      the output is [object Object]
      and when I use valueOf
      trace( item + " :: " + vvalueOf( myLoadedClip_mc.item ) + "\n" );
      the output is _level0
      What I need is to determine what is in each of those properties (or objects, as it were) of the swf I am inspecting; I am presently only getting top-level names, if you will.
      I have tried assigning the item to a new object, and then iterate through that, with no luck.
      Anyone help?
      Thank you very much.
