1 Reply Latest reply on Jan 29, 2008 8:20 AM by catalinanastasoaie
    Installing FLEX Plugin With MyEclipse Plugin
    cxf02 Level 1
      Install Europa first. Install FLEX 3.0 plugin next ang then MyEclipse plugin. If you don't follow this order then there may be features missing from FLEX because the when selecting the Eclipse directory for the FLEX install, you may select the wrong target folder as your Eclipse Root folder. I haven't done an exhastive study on this, but just repaired an install in this manner. Many of us Java programmers use MyEclipse because of Spring, or build capabilities that are built into it. Hopefully, this may help someone down the road.
