3 Replies Latest reply on Feb 5, 2008 3:32 PM by kglad
    Button script
    Python_Design Level 1
      I'm having trouble with the onRelease function. I added the code to a set of buttons on the home page and that worked fine, then added the same buttons on a different page with the same instance names, but code doesn't work when going to internal pages and trying to use the buttons. Funny thing is, that when I test the movie to start from the internal page, its works fine from there. It should be working. Even tried using buttons with different instance names. All the code is added to the first frame of layer called actions.
      Here is a sample code for the button with instance name "f_btn":
      f_btn.onRelease = function () {
      Should I attach the entire .FLA file. I'm using AS2.0 inside Flash CS3, I'm thinking there might be a bug inside Flash CS3.
