26 Replies Latest reply on Nov 23, 2018 2:37 PM by lostinlodos
    Disable or remove Share button new to Acrobat DC
    ianc46124884 Level 1
      After the last update 2018-09, this bright blue Share button appeared.
      And then a pop-up comes telling me what it can do for my life.
      How can we hide the button or at least disable the pop-up
      If I want to share, I will press the e-mail button that was already there, beside print:
        • 1. Re: Disable or remove Share button new to Acrobat DC
          hoegarden31 Level 1
          Problem is that when you press the e-mail button it will open that share menu... So you have to use it.
          We also have problems that the send as attachment does not work when viewing the pdf inside an application. With a rollback to the previous version it resolves that issue.
          2 people found this helpful
          • 2. Re: Disable or remove Share button new to Acrobat DC
            A good answer  to yet another 'improvement' that gets in the way of a day's work.  I hope the pop-up gives up soon.
            • 3. Re: Disable or remove Share button new to Acrobat DC
              theresaw23641767 Level 1
              We send PDFs marked up but do not save them with the markup. We used to be able to email a marked up PDF without saving it. We can no longer do that. Has anyone found a way around that?
              • 4. Re: Disable or remove Share button new to Acrobat DC
                lostinlodos Level 1
                this Has to go. It’s directly over the tools menu On the right side. Every time I mouse over it gives me pop ups and notes and gets in the way.
                In the more visual would, it’s also a glaring blight on the rather friendly design and layout.
                like some 20-something on the development team thought it would be good and stuck it there without any thought to the rest of the program’s users!
                Adobe is just the latest mega company that needs to STOP with all this social interaction stuff.
                Adobe has collaboration tools already and if I wanted to use them I’d buy them.
                I’m still adjusting to the mess of redesign from the move to DC from the standard “boxed” app.
                Much more of this and I’ll end up dumping my CC/DC subscription and going back to the last lifetime version.
                There’s nothing make or break in DC/CC that makes it stand out from X.
                • 5. Re: Disable or remove Share button new to Acrobat DC
                  Peter Greulich Level 1
                  Agree 100%.
                  I really have come to the opinion that Adobe doesn't understand the part of its user community that has a real need to be productive. I may have a need for Adobe pro right now, but I will not buy any other Adobe products. They upgraded my software and in the process, I had to reset the menu back to the way I like it ... something so simple as preserving the end-user's menu layout ... they can't seem to get it right ...  I am sure getting tired of their "new" and "non-productive" updates.
                  Cheers,
                  - Pete
                  • 6. Re: Disable or remove Share button new to Acrobat DC
                    lostinlodos Level 1
                    Exactly on the last two posts.
                    It’s not just THAT it was done either; it’s the WAY it was done!
                    it was tossed on without thought. There’s no way to hide it. The response area extends beyond the edge of the button so clicking NEAR it triggers it.
                    And whatever you do, do NOT pass over it with the mouse pointer! That stupid annoying demo that just won’t die.
                    it doesn‘t end there though. In order to slap this button on you’ve removed my toolbar settings. Icon buttons for actions I NEED have to be recreated.
                    I’ve been using Acrobat since version 6. I switched to Acrobat from Djvu.
                    Many companies have made Adobe’s mistake; innovation for the sake of it without regard to the user base
                    Apple did it when they dumped Jobs and went with System, nearly to the company‘s death. Microsoft did it with windows 8. Both survived Only by making Reversions.
                    The very same thing Adobe is doing here killed OpenOffice.
                    AND 3 of the 5 forks.
                    Djvu is still out there. It’s supported by the largest archive in human history (The Internet Archive).
                    Djvu is a better format with inferior software.
                    smaller files, better quality display, greater control over Layers.
                    Make many more mistakes like this in implementing new “features“ and you may see an exodus to the old standard.
                    • 7. Re: Disable or remove Share button new to Acrobat DC
                      sdacreative Level 1
                      Thank you for posting this!
                      C'mon Adobe, chime in here anytime and explain why you took a simple one-step process and turned it into a three-step process. That is certainly NOT an improvement! Please listen to your constituents and put this back the way it was. Or, at the very least, allow the "share" button to be customizable to what the user wants as well as movable so that big blue (and unnecessary) button can be moved to a location the user prefers. You guys didn't think this one through!
                      • 8. Re: Disable or remove Share button new to Acrobat DC
                        I've developed a tool that replaces the "Share File" menu item under "File" with a "Quick Send" button that will automatically generate a new email and attach the current file to it, bypassing the super-annoying (and slow!) Share panel.
                        If you're using Acrobat you can also add it to the Quick Tools menu, for extremely fast access, and there's a keyboard shortcut to the menu item (Alt+F, Q), if you're on Reader.
                        You can get it for FREE here: Custom-made Adobe Scripts: Acrobat / Reader 2019 -- Quick File Send Button (FREE)
                        • 9. Re: Disable or remove Share button new to Acrobat DC
                          lostinlodos Level 1
                          Or at the very least make it WORK. Passing the pointer over it gives me the demo. Clicking it gives me the demo (I’m on MacOS btw). Ideally we could remove the tool from the toolbar.
                          That users are resorting to coding on their own to fix this mess should tell you something: Adobe.
                          Some ideas can be grown into, eg cloud and recurring licensing.
                          Some ideas simply are bad! The share button is the latter category.
                          • 10. Re: Disable or remove Share button new to Acrobat DC
                            anurag_gupta Adobe Employee
                            Thanks for providing your feedback and sorry for the inconvenience caused to you. While we look into the issue, you can follow the steps in the below article to use the email icon to send PDF directly as email attachment.
                            Link : How to use the email icon to directly send file as attachment
                            Hope this helps. Thanks.
                            3 people found this helpful
                            • 11. Re: Disable or remove Share button new to Acrobat DC
                              sdacreative Level 1
                              Mr. Gupta:
                              Thank you for listening and for the quick patch. Works for me.
                              • 12. Re: Disable or remove Share button new to Acrobat DC
                                Great to hear it helped. Can you please mark it as the correct answer so that others can benefit as well. Thank you!
                                • 13. Re: Disable or remove Share button new to Acrobat DC
                                  lostinlodos Level 1
                                  Thanks mr Gupta for looking at this.
                                  unfortunately This doesn’t actually solve the problem as listed in the OP title.
                                  looking At the file this is simply a redirect. Useful  for those that use the email feature.
                                  Application did solve the constant demo introduction from popping up for me. Which was my larger annoyance.
                                  i wonder if modifying that location to null would disable it?
                                  Disable or remove was the original posted request.
                                  There remains a bug of sorts in the implementation, clicking next to but NOT on the button still registers as a click.
                                  Thankfully with a tap of escape I can now get back to work.
                                  So where we are at now;
                                  can Adobe please look into the button size in the software, it’s obviously larger than the button itself. If a simple plist can change the feature I see a security issue for a malicious actor To exploit.
                                  Regarding the original question any suggestion on a dummy location I should/could point to to disable the icon silently? I’m about to try null just to see what happens. Hopefully nothing breaks.
                                  • 14. Re: Disable or remove Share button new to Acrobat DC
                                    Hi, Can you please send the screenshot of the issue you are describing above? Which demo is popping up for you? Regarding disabling Share button, we will evaluate the request for our future releases. Thanks.
                                    • 15. Re: Disable or remove Share button new to Acrobat DC
                                      Hi Gupta!
                                        Thanks for taking this issue up.
                                      It is was not a demo pop-up, but a quite large rectangle (see the sketched-on frame on the screen dump)  that wanted to draw my attention to the new button.  I suppose it said very much similar to that which is now displayed as a "tool-tip" on the screen dump, but with pictograms and things.
                                      Since 'Sharing' is not in my normal vocabulary for work (either I forward a file or I save it), I am afraid I did not pay any close attention.  I just needed it out of the way.
                                      It appears now to have gone away.  Maybe it was just the first day or two ? It was at any rate in the way of what I wanted to read, and I in general do not want pop-ups.  I do always review "what's new?" messages when there is an update, but I do that when I am ready, not when I am very busy with people waiting for an answer.
                                      Kind regards,
                                      Ian Castle
                                      Product Development &
                                      Compliance Advisor
                                      Scan Tech AS
                                      Finnestadsvingen 23,
                                      Pb.738 4004 Stavanger, Norway
                                      Direct:    (+47) 51 54 54 14
                                      Mobile:    (+47) 928 07 860
                                      Internett:   www.scan-tech.no
                                      This email and its attachments are intended solely for the addressee and any information contained therein is confidential. If you are not the intended recipient of this email, please notify the sender by reply email or by telephone as soon as possible.  Do not copy or disclose its contents to any third party; and note that any action taken on the basis of its contents may be prohibited and/or unlawful. Any views expressed in this email are those of the author and do not necessarily represent those of Scan Tech AS or its subsidiary companies.
                                      Fra: anurag_gupta <forums_noreply@adobe.com>
                                      Sendt: onsdag 10. oktober 2018 11.50
                                      Til: Ian Castle <ic@scan-tech.no>
                                      Emne:  Disable or remove Share button new to Acrobat DC
                                      created by anurag_gupta<https://forums.adobe.com/people/anurag_gupta> in Acrobat General Troubleshooting - View the full discussion<https://forums.adobe.com/message/10669359#10669359>
                                      • 16. Re: Disable or remove Share button new to Acrobat DC
                                        barbarak10411712 Level 1
                                        the registry edit is helpful, thank you
                                        but the new 'share' button is very distracting, and we should have the ability to turn off, just like any other part of the toolbar...
                                        • 17. Re: Disable or remove Share button new to Acrobat DC
                                          hoegarden31 Level 1
                                          Still the fact that we need to edit the registry for something this simple and was working in the previous version shows that this is not what users want... But better having a fix than nothing i guess.
                                          • 18. Re: Disable or remove Share button new to Acrobat DC
                                            dhsa-llp Level 1
                                            Agree that the blue messages like this "Share" popup (or whatever these promotional messages are called these days) shown in the attached image, is one of the annoying features of the most recent update to Adobe Acrobat Pro DC.
                                            As if the other changes to layout and interface were not disruptive enough, this kind of nonsense has no place in a product marketed as "Pro" (as in professional). Or has that word too been abused into utter meaninglessness by marketers?
                                            • 19. Re: Disable or remove Share button new to Acrobat DC
                                              lostinlodos Level 1
                                              I believe this was directed at me. The “demo” is, was, when the screven turned grey and a little comic book bubble came up to welcome the new button. For whatever reason it happened every time the mouse got near the button.
                                              After a few restarts and turn around a it turned into the “tool tip” that is excessively over sized compared to other tool tips.
                                              The above modification plist has fixed the issue. I don’t se why, but I’m happy it’s gone.
                                              the button is still in the way but like other useless stuff in software I can learn to live with it; work around it.
                                              I reiterate this looks like something some young kid stuck in at the last second so it wouldn’t be turned down.
                                              Mad an above user stated this doesn’t really belong in a “pro” version. A “pro” would use the far more advanced collaboration tools offered by Adobe. Those who need to email documents will use the email button. It far more likely just email an attachment in their mail software of choice.
                                              I’m not happy. I’ve had every Windows desktop version of acrobatic since 6. And happily and played the puppy and wagged my tail with an open wallet when the next update came out. I was one of the few devastated users who mourned the loss of desktop Acrobat!
                                              Moving to MacOS left me no choice but CC. So here we are, being less satisfied but content. Then you slap kiddy button in and give us no way to move it.
                                              For users who manage, verify, compare, and merge documents that window real estate is a must.
                                              Suddenly changing things disrupts years of learned workflow.
                                              Adobe really should consider what the core users want when they look for gimmicks to bring on new users.
                                              i Chose to come HERE to make my voice heard but the Internet is Full of people complaining about this elsewhere.
                                              Mid you make enough of your core mad, you could quickly find one of the other layout applications would quickly step up. Both Microsoft and DjVu remain in use, are cross system compatible, and knocking on the back door.
                                              I personally prefer PS/PDF over the other two. It’s generally easier to work with for less complex documents.
                                              But like many others, if toys get in the way I’ll move on.
                                              • 20. Re: Disable or remove Share button new to Acrobat DC
                                                hansm38969220 Level 1
                                                One more vote to stop disrupting the user interface.
                                                This button is ugly, annoying, way too big and always blocking something useful. To prevent users from disabling this little bugger, some marketing guys disabled the disabling. So that is how customers are treated?
                                                • 21. Re: Disable or remove Share button new to Acrobat DC
                                                  johng78495102 Level 1
                                                  Hello Mr. Gupta,
                                                  But is there a way to hide the "share", "provide feedback", and "learn adobe DC) buttons from the toolbar? They take up far too much real estate and make it so I cannot have the tools that I want to quickly access in the toolbar when I shrink the window down to the width of the page I am viewing.  This is a big economical problem for when I want to review and annotate multiple documents at a time.
                                                  See below: the ability to only have 8 tools visible in the tool bar (the page numbers should not even count as tools) when reviewing an 8.5 x 11 document in page view on a 27" monitor is a problem.
                                                  Please give us the ability to show/hide whatever we want in the tool bar. Productivity is everything and the inability to remove unwanted items has a significant negative effect on mine. It sounds like this is negatively affecting most everyone else who uses the product also.
                                                  Thank you.
                                                  • 22. Re: Disable or remove Share button new to Acrobat DC
                                                    fumblerooskie Level 1
                                                    I echo the frustration of others. This is a really sad "enhancement" that simply gets in the way. It's unnecessary, inconvenient, ill-considered, annoying, and ultimately frustrating that it can't be removed. This kind of arrogant we-know-better-than-you-what-you-need from Adobe isn't winning any friends.
                                                    PLEASE REMOVE IT OR ALLOW US TO.
                                                    • 23. Re: Disable or remove Share button new to Acrobat DC
                                                      mcswell1 Level 1
                                                      lostinlodos wrote: "I’ll end up dumping my CC/DC subscription and going back to the last lifetime version."  FWIW, there are free PDF readers/ editors that can do many of the same things that Acrobat does.  On my home PC, I use PDF-xchange editor.  It's free; there is also a paid version that has more editing capabilities.  If you like icons, it uses color icons rather than the ugly 1980s-era gray-and-black icons that Acrobat has (except for this new Share icon, which is inexplicably blue).  If you don't like icons (I don't), then you can turn them off permanently in your preferences and just use the menu.  Or vice versa.  PDF-xchange works under Windows; I assume there are similar tools for Macs and Linux.
                                                      • 24. Re: Disable or remove Share button new to Acrobat DC
                                                        lostinlodos Level 1
                                                        I agre. Acrobat is overkill for most people. I use multiple programs, free and paid, for different actuons with PDF files.
                                                        For instance I sue Fine Reader for OCR; expensive but really the current leader by many technology generations over everyone else, including Adobe. Unlike acrobat fine reader can save ocr and display changes underneath the visual display; where acroba permanentlay damages text display when tuning ocr.
                                                        I use X-scribe, free, for removing botched ocr layers. Something that cannot, realistically, be done in acrobat at all.
                                                        But there are two things acrobatic has always done better than everyone else. Excising, as opposed to ignoring, cropped items.
                                                        And bulk batch conversions to pdf.
                                                        • 25. Re: Disable or remove Share button new to Acrobat DC
                                                          halzion Level 1
                                                          I stopped using Acrobat Reader DC, because this useles button is taking way too much space from my toolbar.
                                                          Other competing programs allow me to set my own tools and not force down useless Adobe features that I don't use down my throat.
                                                          • 26. Re: Disable or remove Share button new to Acrobat DC
                                                            lostinlodos Level 1
                                                            Well; here I am now. I found another program that is almost as good as Acrobat. I’ve given up a few benefits in automated cropping, but editing and redaction are actually better.
                                                            I would have waited, and eventually come back to Acrobat once this glaring bug was addressed. However adobe chose to charge me on the way out the door.
                                                            I’m livid!
                                                            i have two registered accounts. One dates back to 2006. The other pre-dates the internet and was created by POSTAL MAIL card.
                                                            I’ve Been loyal and outspoken in my support.
                                                            This is how you treat me?  Charge me $40? Too bad. One more customer who won’t come back.
                                                            keep this up you’ll quickly go out of business!
