Expand my Community achievements bar.
SOLVED
Automatic version creation for an asset when it is modified.
Avatar
Level 2
Hi Team,
When i modify asset properties a new version is automatically created under the path " /jcr:system/jcr:versionStorage ". Asset node contains the property 'jcr:versionHistory', this is where we can find the version of the asset. I want to find the process that is responsible for the automatic version creation. Is there any way to disable the functionality of automatic version creation.
Thanks.
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
I don't think so there is a bug. It says that when you update image from WebDav then only versioning would be disabled.
If you don't want to keep Version fro assets, you can delete version from JCR using Version Purging API or schedules Version Purging
Version Purging http://docs.jboss.org/modeshape/4.0.0.Final/api/org/modeshape/jcr/api/version/VersionManager.html
Arun Patidar
View solution in original post
Avatar
Community Advisor
As soon as you update metadata , a workflow(DAM_METADATA_WRITEBACK_WORKFLOW) is triggered which Write back Metadata and which triggered the event and Event is responsible to create version
Managing Assets with the Touch-Optimized UI
Arun Patidar
Avatar
Level 2
Hi Arun,
Thanks for sharing the document it is very useful. I have gone through the documentation, in the document it is mentioned that for the configuration 'com.adobe.cq.dam.webdav.impl.io.AssetIOHandler.name' we have the property create version. If we un-check it then versions does't get created. I have unchecked it and made modifications for my asset, still i can see that version getting created. Do you think that its an aem bug? or am i missing something.
Avatar
Correct answer by
Community Advisor
Arun Patidar
