Hola, Adobe no es capaz de verificar correctamente las firmas con el DNIe Español. Una firma válida la indica como "Certificado no válido para utilizarse".
Cómo hace Adobe la interpretación de la RFC 5280 para que no se muestre la firma como válida?
La tarjeta de Identificación de los españoles con capacidad de autenticación y firma digital la tienen 40 millones de Españoles y Adobe no valida correctamente las firmas.
Muchas gracias,
Juan
Hello, Adobe is not able to correctly verify the signatures with the DNIe. A valid signature indicates it as "Certificate not valid for use".
How does Adobe interpret RFC 5280 so that the signature is not shown as valid?
The Spanish ID card with authentication capacity and digital signature has 40 million Spaniards and Adobe does not correctly validate the signatures.
Thank you very much,
Juan
Hi juane,
As per the issue description mentioned above, you are facing issue with digital signatures, is that correct?
Try adding the signature certificate to "trusted identity" using the steps given in the following forum thread ( under correct answer) and check if that helps:
You may also refer to the following help document for more info:
Validating digital signatures, Adobe Acrobat
Let us know if you need any help.
Shivam
same problem...
