1 Reply Latest reply on Nov 20, 2018 5:14 AM by Adorobat
    Outlook PDF Attachment 2018
    michaelslwha
      I have Acrobat 2010 installed on Windows 10 Pro.
      I received and email with a PDF attachment.  I opened the
      attachment okay.  But when I open my comparison PDF on a
      mapped network drive it will not open.  So from an outlook
      attached PDF to a local PDF acrobat will not open.  If I open the
      local file first then open the attachment in outlook they
      both will open.  I need to be able to open outlook first then
      open the local file.  Any ideas how to fix this?
      Thanks, Michael Smith
        • 1. Re: Outlook PDF Attachment 2018
          Adorobat Adobe Employee
          Hi Michael,
          Sorry for the delay in response.
          As per the issue description mentioned above, you are unable to open a pdf ( located on a mapped network drive) after successfully opening a pdf attachment (received in an email, in Outlook), is that correct?
          Could you try adding the network drive location under privileged location in Acrobat using the steps given in the following help document and try again: Enhanced security setting for PDFs, Adobe Acrobat
          Let us know how it goes.
          Shivam
