1 Reply Latest reply on Jul 18, 2006 4:17 PM by Newsgroup_User
    Using complex item renderer as item editor does not work
    KenichiM Level 1
      I'm trying to use a custom/complex item renderer as an item editor in a data grid. I'm following the example in the Developer Guide, pg. 749. But it does not seem to work. The values are reflected but when I edit and then sort the column, the item reverts back to its original value, indicating that the item editor is not being hooked up. Has anyone had success with this?
        • 1. Re: Using complex item renderer as item editor does not work
          Level 7
          You need to notify the datagrid to update its display. For a detailed
          example lookup notifyItemUpdate in the help documentation.
          winsha
