0 Replies Latest reply on Oct 9, 2018 3:13 PM by lucas amaral
    How to generate .apk file on linux sistems?
    lucas amaral
      After a lot of trouble to instal Phonegap, cordova Android sdk, setting theyr PATH variables, home variables, finding the right version of java (wich is 8, by the way), I still am unable do generate an .APK file. Obviously, I am using Phonegap CLI version. Documentation, both on Android and Cordova for command-line tools are both terribly poor.
      There is what I did, created a project "phonegap create com.phonegap.test" includded android "phonegap add android" build, install, everything else "phonegap run android", "phonegap run", everything I could think of. The file was supposed to have been created, but no.
      Cordova requirements seems to be all ok
      Android Studio project detected
      Requirements check results for android:
      Java JDK: installed 1.8.0
      Android SDK: installed true
      Android target: installed android-26
      Gradle: installed /usr/share/gradle/bin/gradle
      On "phonegap run android -d", I have gotten those lines (not all included)
      publishNonDefault is deprecated and has no effect anymore. All variants are now published.
      The Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Please use Task.doLast(Action) instead.
              at build_882bvtp51s2odch9l4ea9w43g.run(/home/xxxxx/Documentos/PhoneGap/com.phonegap.teste/pl atforms/android/app/build.gradle:143)
      Configuration 'compile' in project ':app' is deprecated. Use 'implementation' instead.
      16:5-74 Error:
              uses-sdk:minSdkVersion 14 cannot be smaller than version 16 declared in library [:CordovaLib] /home/lucas/Documentos/PhoneGap/com.phonegap.teste/platforms/android/CordovaLib/build/int ermediates/manifests/full/debug/AndroidManifest.xml as the library might be using APIs not available in 14
              Suggestion: use a compatible library with a minSdk of at most 14,
                      or increase this project's minSdk version to at least 16,
                      or use tools:overrideLibrary="org.apache.cordova" to force usage (may lead to runtime failures)
      :app:processDebugManifest
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':app:processDebugManifest'.
      > Manifest merger failed : uses-sdk:minSdkVersion 14 cannot be smaller than version 16 declared in library [:CordovaLib] /home/xxxx/Documentos/PhoneGap/com.phonegap.teste/platforms/android/CordovaLib/build/inte rmediates/manifests/full/debug/AndroidManifest.xml as the library might be using APIs not available in 14
      * Try:
      Run with --stacktrace
      option to get the stack trace. Run with --info or --debug option to get more log output.
      * Get more help at https://help.gradle.org
      BUILD FAILED in 7s
      Please, ADOBE, make things right, name all that you need and use for phonegap and cordova, PLEASE, I am tired of searching everywhere on internet so solve problems of your platform.
      I just want to build a single apk, no matter the version of the android, I have installed the version 26 on my computer.
      $ phonegap -v
      8.0.0
      $ phonegap platforms
      Installed platforms:
        android 7.0.0
      Available platforms:
        browser ~5.0.1
        ios ~4.5.4
        osx ~4.0.1
        windows ~5.0.0
        www ^3.12.0
      $ phonegap plugins
      cordova-plugin-battery-status 1.2.5 "Battery"
      cordova-plugin-camera 2.4.1 "Camera"
      cordova-plugin-compat 1.2.0 "Compat"
      cordova-plugin-device 1.1.7 "Device"
      cordova-plugin-dialogs 1.3.4 "Notification"
      cordova-plugin-file 4.3.3 "File"
      cordova-plugin-geolocation 2.4.3 "Geolocation"
      cordova-plugin-globalization 1.0.9 "Globalization"
      cordova-plugin-inappbrowser 1.7.2 "InAppBrowser"
      cordova-plugin-media-capture 1.4.3 "Capture"
      cordova-plugin-network-information 1.3.4 "Network Information"
      cordova-plugin-vibration 2.1.6 "Vibration"
