2 Replies Latest reply on Oct 23, 2018 3:18 AM by Loic.Aigon
    Import multiple XML files not working
    T_Stevens
      I'm working on a quiz booklet where each question is in its own xml file, so I'm trying to import multiple XML files into a single InDesign document. I'm attempting to append each XML inside the Root element, so I can just place the root into a text frame and have all the questions in a single story. My code is below, but it errors out and I can't figure out why.
      var myTransform = File.openDialog("Select XSL transform");
      var myXMLImportPreferences = myDoc.xmlImportPreferences;
      myXMLImportPreferences.allowTransform = true;
      myXMLImportPreferences.createLinkToXML = true;
      myXMLImportPreferences.ignoreUnmatchedIncoming = false;
      myXMLImportPreferences.ignoreWhitespace = false;
      myXMLImportPreferences.importCALSTables = true;
      myXMLImportPreferences.importStyle = XMLImportStyles.appendImport;
      myXMLImportPreferences.importTextIntoTables = false;
      myXMLImportPreferences.importToSelected = true;
      myXMLImportPreferences.removeUnmatchedExisting = false;
      myXMLImportPreferences.repeatTextElements = false;
      myXMLImportPreferences.transformFilename = myTransform;
      var xmlFolder = Folder.selectDialog("Select the folder with the XML files");
      if(xmlFolder !=null){
          var xmlFiles = GetSubFolders(xmlFolder); //returns array of all xml files in xmlFolder and its subfolders
      main();
      function main(){
          for(var x = 0; x < xmlFiles.length; x++){
              $.writeln(xmlFiles[x].name);
              if(xmlFiles[x] != null){
                  app.select(myDoc.xmlElements.item(0));
                  myDoc.importXML(xmlFiles[x]);
      The error occurs on line 30, and all Extendscript does is highlight that line and display "importXML" where the error would normally appear. If I manually import the XML files, everything works. I don't have any issues with the xml or the transform. This code worked once, but only once, and every time since then, I get the same weird "importXML" error.
      Any ideas?
        • 1. Re: Import multiple XML files not working
          T_Stevens Level 1
          Here's a fun new development, the code works great if I don't include a transform. If I set myXMLImportPreferences.allowTransform to false, it runs with no errors. When I set it back to true, the script errors after 0-2 xml files import.
          The transform I'm using strips out some non-printing elements and strips excess whitespace. Without it, I get a bunch of extra hard returns and tabs and a bit of text.
          • 2. Re: Import multiple XML files not working
            Loic.Aigon Adobe Community Professional
            May your XSLT file be Version 2.0 ?
            Otherwise, you may make your code more solid by ensuring a file is actually selected and is XSLT format:
            var main = function() {
            var doc = app.properties.activeDocument,
            xslt, xmlFiles;
            if ( !doc ) {
            alert("You need an open document" );
            return;
            xslt =  getXSLT();
            if ( !xslt ) return;
            setXMLImportOptions(doc, xslt.fsName );
            xmlFiles  = getXMLFiles();
            if ( !xmlFiles.length ) {
            alert("No XML files found, sorry !");
            return;
            importXMLFiles ( doc, xmlFiles );
            var u;
            app.doScript ( "main()",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
            function importXMLFiles(doc,xmlFiles) {
            var n = xmlFiles.length;
            xmlFiles.reverse();
            while ( n-- ) doc.importXML(xmlFiles[n]);
            function getXMLFiles(){
            if ( !xmlFolder ) return [];
            return GetSubFolders(xmlFolder); //returns array of all xml files in xmlFolder and its subfolders
            function setXMLImportOptions(doc, xslt) {
            doc.xmlImportPreferences.properties = {
            allowTransform:true,
            createLinkToXML:true,
            ignoreUnmatchedIncoming:false,
            ignoreWhitespace:false,
            importCALSTables:true,
            importStyle:XMLImportStyles.appendImport,
            importTextIntoTables:false,
            importToSelected:true,
            removeUnmatchedExisting:false,
            repeatTextElements:false,
            transformFilename:xslt
            function getXSLT(){
            var mac = $.os[0]=="M",
            macFilter = function(f){return /\.xslt?$/i.test(f.name) },
            winFilter = "XSL Files : *.xsl;",
            filter = mac ? macFilter : winFilter,
            f = File.openDialog("Please select XSL file", filter );
            return f;
