3 Replies Latest reply on Jan 22, 2008 6:56 AM by fredchoum
    Stop on each diapo
    fredchoum
      Hello,
      I develop captivate project based on a powerpoint diaporama. But I want that it's published the user click on a button on each diapositive. Is there somewhere an option to do it ? The published project is automatic.
      Sorry for my bad english.
      thanx
        • 1. Re: Stop on each diapo
          Hi fredchoum and welcome to our community
          I'm not sure what a diaporama is. I did conduct a Google search and looked at Wikipedia, but returned empty handed. Based on your context, I'm guessing it may mean "Slide Show"?
          What version of Captivate are you using? If it's version 3, you should have an option to automatically advance the slides or to use a Click Box object on each slide. If you would like to add buttons, just add a single button on slide 1, configure it to go to the next slide when clicked. Then copy the button, select all the other slides, then paste. The button should be placed on each of the other slides in the same position as where you copied it from.
          Hopefully this helps a bit... Rick
          • 2. Re: Stop on each diapo
            fredchoum Level 1
            Thank you.
            Sorry, a "diaporama" is a slide show.
            • 3. Re: Stop on each diapo
              fredchoum Level 1
              Thank you.
