Hi!
I'm working with Adobe Pro DC. I've created an Action to OCR multiple documents at a time, but it is displaying the "Recognize Text - General Settings" prompt between each document. How/Can I stop that, so I can select once and it will apply to all of the documents? The last action step I added was to save the documents. Is there a way to make it close all of the documents too? I hate to sit here and hit "close" for dozens of documents.
Thanks for your help
Disable the user prompt.
Thank you for the response.
I've seen and read that you should check or uncheck the prompt user box for various actions, however when I check it or uncheck it for some reason it doesn't change anything.
I found a solution that worked for me: under the edit actions tab I selected "Add Instruction" and typed save and close...and it WORKED!
For the life of me I can't figure out why unchecking the prompt box doesn't work, but at least I found a work around.
