4 Replies Latest reply on Jan 23, 2008 1:44 PM by Peter Grainge
    RoboHelp X5 on Terminal Server
    David_Browne
      We are running RH X5 on a terminal server, and two remote employees are both logging into the server, accessing RH and doing a get latest in Visual Source Safe (which is on a network server) to pull down a project to their profiles on the terminal server. Both have the same rights in their individual profiles, yet one can successfully pull the project down to his profile and open it successfully in RH. The other employee can pull it down to her profile, but when she opens the project and RH performs a get latest, it always fails on the last two files and displays an Application Error message box and the program terminates.
      Any help would be greatly appreciated.
      Dave Browne
      Fiserv
        • 1. Re: RoboHelp X5 on Terminal Server
          MergeThis Level 4
          Working with RH on a network (that includes virtual servers) should never be attempted, as attested to by the thousands of times we've mentioned here on the forum.
          You can check out files from source control over a network, but your RH license and your RH project must be on your local machine. Sorry.
          Leon
          • 2. Re: RoboHelp X5 on Terminal Server
            David_Browne Level 1
            Well, it is working fine for employee number one, and the second employee using it on Terminal Server is able to open and update files in a number projects except for the one issue i mention above.
            • 3. Re: RoboHelp X5 on Terminal Server
              I'm new to this forum, but I just ran a search of "virtual server" and found no content at all. Perhaps you or someone could explain why RH would know or care that it is running on a virtual machine versus a physical machine?
              Thanks in advance,
              Dave Browne
              Leon
              Text
              • 4. Re: RoboHelp X5 on Terminal Server
                It's the way it is installed and that is to do with the licence. Speak to Adobe Customer Support for information about where you can install within the licence terms.
