0 Replies Latest reply on Oct 11, 2018 7:04 AM by lglmrc
    Palette simulate Dialog
    lglmrc Level 1
      Hello,
      I made a short routine which reads some texts from an external text file and search for the corresponding data in an open document.
      Every time the routine finds an occurence, it shows a dialog box and fills the content of an "edittext" with some data from the text file.
      this is my code:
      #target "InDesign-8.0"
      //Create colours
      try{
          myDoc.colors.item("RED").name;
      catch (myError){
          myDoc.colors.add({name:"RED", model:ColorModel.process, colorValue:[15, 100, 100, 0]});
      var txtFile = File.openDialog("Open .txt file", "Files Txt:*.Txt");
      if (txtFile == null) exit();
      var txtArr = ReadTxtData(txtFile);// array of data
      var foundArticles = 0;
      for(i=0; i<txtArr.length; i++){
           try{
              var myPart, myCode, myDesc, myDesc2;
              if(txtArr[i][0] && txtArr[i][0] != ""){
                  var myPart = txtArr[i][0];
              if(txtArr[i][1] && txtArr[i][1] != ""){
                  var myCode = txtArr[i][1];
              if(txtArr[i][2] && txtArr[i][2] != ""){
                  var myDesc = txtArr[i][2];
              if(txtArr[i][3] && txtArr[i][3] != ""){
                  var myDesc2 = txtArr[i][3];
              app.changeGrepPreferences = NothingEnum.nothing;
              app.findGrepPreferences = NothingEnum.nothing;
              app.findGrepPreferences.findWhat = '\\b'+myCode+'\\b';
              app.changeGrepPreferences.fillColor = "RED";
              var finds = myDoc.findGrep();
              if (finds.length > 0) {
                  app.changeGrep();
                  foundArticles ++;
                  var myPage = finds[0].parentTextFrames[0].parentPage;
                  var myText= finds[0].parentTextFrames[0];
                  myText.select();
                  //========================<  DIALOG WINDOW   >===========================
                  var w = new Window ("dialog");
                  w.size = [450,180];
                  w.margins = 5;
                  var messPanel = w.add('panel', undefined);
                  messPanel.size = [430,100];
                  var buttonPanel = w.add('panel', undefined);
                  buttonPanel.size = [430,50];
                  buttonPanel.margins = 5;
                  buttonPanel.orientation = "column";
                  buttonPanel.alignChildren = "center";
                  var okButton = buttonPanel.add ("button", undefined, "OK");
                  okButton.size = [150,35];
                  if(myDesc != null && myDesc2 != null){
                      var mess1 = messPanel.add('edittext', undefined, myPart + " / " + myCode + ": " + myDesc + " - " + myDesc2, {multiline:true});
                      mess1.size = [430,80];
                  }else if(myDesc != null){
                      var mess1 = messPanel.add('edittext', undefined, myPart + " / " + myCode + ": " + myDesc, {multiline:true});
                  w.onShow = function() {
                      this.frameLocation = [1100,600];
                  w.show();
                  //=======================< \ DIALOG WINDOW   >=========================
              //Reset the find/change grep preferences after each search.
          }catch(e){
      if(foundArticles > 0){
          alert("Found "+ foundArticles + " Articles");
      function ReadTxtData(txtFile) {
          var line, temp, txtRecord, tempArr;
          var txtData = [];
          txtFile.open("r");
          while (!txtFile.eof) {
              line = txtFile.readln();
              tempArr = line.split("\t");
              txtData.push(tempArr);
          txtFile.close();
          return txtData;
      The fact is that using a dialog window, I cannot move the document to fit with its contents.
      I'd like to use a palette window instead, and pause the routine every time I find an occurrence.
      Any idea would be much appreciated.
      Thanks in advance,
      Marco
