2 Replies Latest reply on Jul 5, 2006 11:26 AM by tjforce
    Install as JRun Error
    tjforce
      I installed the Flex Data Services using the JRun option. It installed fine, no errors. When I try to run Start Integrated Flex Server I am getting the following:
      Starting Macromedia JRun 4.0 (Build 106363), default server
      Flex OEM License for JRun enabled
      06/29 13:34:22 warning Unable to open C:\fds2\jrun4/lib/license.properties
      06/29 13:34:23 info JRun Naming Service listening on *:2907
      06/29 13:34:23 info No JDBC data sources have been configured for this server (s
      ee jrun-resources.xml)
      06/29 13:34:23 info JRun Web Server listening on *:8700
      06/29 13:34:23 info Deploying web application "Flex Default Web Application" fro
      m: file:/C:/fds2/jrun4/servers/default/default-war/
      06/29 13:34:23 user JSPServlet: init
      06/29 13:34:23 info Deploying web application "Flex Data Services" from: file:/C
      :/fds2/jrun4/servers/default/flex/
      06/29 13:34:24 user FlexMxmlServlet: init
      Loading configuration file C:\fds2\jrun4\servers\default\flex\WEB-INF\flex\flex-
      webtier-config.xml, root element flex-webtier-config
      config.xml, root element flex-config
      06/29 13:34:24 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler (beta
      period ends Jul 31, 2006)
      06/29 13:34:24 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 138139
      06/29 13:34:24 user MessageBrokerServlet: init
      06/29 13:34:24 user FlexSwfServlet: init
      06/29 13:34:24 user FlexInternalServlet: init
      06/29 13:34:24 info Deploying web application "Flex Admin Web Application" from:
      file:/C:/fds2/jrun4/servers/default/flex-admin/
      06/29 13:34:25 user JSPServlet: init
      06/29 13:34:25 user MessageBrokerServlet: init
      06/29 13:34:25 info Deploying web application "Flex Data Services Samples" from:
      file:/C:/fds2/jrun4/servers/default/samples/
      06/29 13:34:25 user FlexMxmlServlet: init
      Loading configuration file C:\fds2\jrun4\servers\default\samples\WEB-INF\flex\fl
      ex-webtier-config.xml, root element flex-webtier-config
      ex-config.xml, root element flex-config
      06/29 13:34:26 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler (beta
      06/29 13:34:26 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 138139
      06/29 13:34:26 user MessageBrokerServlet: init
      [Flex] [INFO] Starting Adobe Flex Data Services 2.0 Enterprise (beta period ends
      Jul 31, 2006)
      [Flex] [INFO] Adobe Flex Data Services Build: 138139
      [Flex] [INFO] Endpoint my-amf created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/amf
      [Flex] [INFO] Endpoint my-polling-amf created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolli
      ng
      [Flex] [INFO] Endpoint my-http created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/http
      [Flex] [INFO] Endpoint my-secure-amf created with security: None
      at URI: https://{server.name}:9100/{context.root}/messagebroker/amfsecure
      [Flex] [INFO] Endpoint my-rtmp created with security: None
      at URI: rtmp://{server.name}:2037
      [Flex] [INFO] Endpoint my-secure-http created with security: None
      at URI: https://{server.name}:9100/{context.root}/messagebroker/httpsecure
      06/29 13:34:26 user FlexSwfServlet: init
      06/29 13:34:26 user FlexInternalServlet: init
      06/29 13:34:26 info Deploying enterprise application "JRun 4.0 Internal J2EE Com
      ponents" from: file:/C:/fds2/jrun4/lib/jrun-comp.ear
      06/29 13:34:26 info Deploying EJB "JRunSQLInvoker" from: file:/C:/fds2/jrun4/lib
      /jrun-comp.ear
      Server default ready (startup time: 5 seconds)
      Any ideas?
