2 Replies Latest reply on Oct 15, 2018 8:08 PM by jshannon00
    Premiere 2019 UNDO command does not work for Effects Controls
    jshannon00
      With the Abode Premiere Pro 2019 update the "undo" command (ctrl+z) does not work on changing values in Effects Controls. If I make an edit in the timeline, then change a value in the Effect Controls, for example make opacity 50%, when I use ctrl+z it undoes the edit in the timeline, not the effect change in Effect Controls. Using the Edit>Undo menu option does not work either. I've tried this on Motion, Opacity, Lumetri and third party effects, nothing works. I have Premiere 2018 still installed and I've confirmed ctrl+z still works properly with that version.
      Mac OS 10.13.6 on Mac Pro (Mid 2012)
