6 Replies Latest reply on Jan 25, 2008 4:53 PM by Wolfgang Herold
    Quicktime movie w/alpha channel
    1serg1
      I am working with Dir.MX2004 (Mac OSX). I have imported a quicktime movie with an alpha channel, but I am unable to get the alpha channel to show up. I've searched some previous posts but they don't answer the problem.
      Please help. I'm sure someone out there can explain.
      Thanks!!!
        • 1. Re: Quicktime movie w/alpha channel
          Level 7
          > I am working with Dir.MX2004. I have imported a quicktime movie with an alpha
          You can't use an alpha channel with QuickTime video in Director. You
          could try running it non-DTS and use a sprite ink setting, or use a
          1-bit mask with the member.
          • 2. Re: Quicktime movie w/alpha channel
            Wolfgang Herold Level 2
            If you want to use alphachannel, you can convert the video to Flashvideo with on2VP6 Codec. I dont know if that works on
            a Mac, on WIndows it works fine.
            Wolfgang
            • 3. Quicktime movie w/alpha channel
              1serg1 Level 1
              "You can't use an alpha channel with QuickTime video in Director. You
              1-bit mask with the member."
              It's my undersatnding that a 1-bit mask can only be used with a bitmap. If I have a video with many frames, do i have to create a mask for each?
              thanks for the reply.
              • 4. Re: Quicktime movie w/alpha channel
                1serg1 Level 1
                Wolfgang
                I'll look into this and see if it works. I'll report back. thanks!
                • 5. Re: Quicktime movie w/alpha channel
                  1serg1 Level 1
                  Wolfgang
                  Unfortunately it doesn't work with a Mac.
                  • 6. Re: Quicktime movie w/alpha channel
                    How did you do it.
                    Started Premiere cs3 with custom settings, set in videorendering
                    maximum depth to get 32bit
                    then imported my video as singleframe with alpha to premiere,
                    and put it on the second video layer.
                    Export with adobe Mediaencoder to flv with video w alpha setting.
                    Mybe this will help you
                    Wolfgang
