Hi Adobe fans
how do i delete small images in a folder ?
var folder = Folder.current;
var files = folder.getFiles("*.png");
for (var f = 0; f < files.length; f++) {
if (files
.size < 10000 ){ alert(files
.name +" deleted ") files
.remove(); }
The File.length property shows your the file size.
According to the OMV, it doesn't appear that file size is available to us.. I looked through all the available properties and methods and nothing points in that direction.. I also tried some 'common sense' options that aren't listed and none of those worked either.
Is there some specific reason that you want to do this task from illustrator? It sounds like a task better suited for a shell script.
My script is create images files from the layers "png files"
But when a layer is empty it create a small black square png image.
can I make a: if a layer is empty don't run the export function?
So your script exports each layer as a PNG, then you want to retroactively go back and delete any PNGs that were exported from empty layers?
Can you share the script that you're using so i can try to make some suggestions? My inclination is that you should check to see if a layer is empty before exporting it, rather than exporting it and then deleting it later.
ah, yes. of course... because calling that property "size" or "fileSize" would have been confusing. instead, let's go with a name that's almost always used to denote an integer count of elements in an array.
var options = new ExportOptionsPNG24();
options.horizontalScale = 400;
options.verticalScale = 400;
options.antiAliasing = false;
options.transparency = true;
var document = app.activeDocument;
if (document && folder)
parseLayer(document, "", 1);
function parseLayer(layer, base, depth) {
alert
var popups = [];
var takeShots = true;
log(depth, "parsing " + layer.name);
for (var i = 0; i < layer.layers.length; i++) {
var l = layer.layers;
var name = l.name;
var subLayer = true;
if (name.indexOf("(+)") != -1) {
l.visible = true;
subLayer = false;
log(depth + 1, name + " : always on");
else
if (name.indexOf("(-)") != -1) {
l.visible = false;
subLayer = false;
log(depth + 1, name + " : always off");
else
if (name.indexOf("(~)") != -1) {
l.visible = false;
subLayer = false;
popups.push(l);
else {
slides.push(l);
log(depth, "slides = " + slides);
// hide all popups
for (var i = 0; i < popups.length; i++)
popups.visible = false;
for (var i = 0; i < slides.length; i++) {
var l = slides;
// show current slide, hide all the others
for (var j = 0; j < slides.length; j++) {
slides
log(depth, "setting " + slides
parseLayer(l, base + (base == "" ? "" : "-") + l.name, depth + 1);
takeShots = false;
// hide all slides
slides.visible = false;
// capture popups
for (var i = 0; i < popups.length; i++) {
var l = popups;
l.visible = true;
var fname = base + "-" + l.name + ".png";
var file = new File(folder.fsName + "/" + fname);
log(depth, " capture <" + fname + ">");
document.exportFile(file, ExportType.PNG24, options);
l.visible = false;
if (takeShots) {
var fname = base + ".png";
Final
$.writeln("==================");
$.writeln("Begin... ");
var slides = [];
var popups = [];
var name = l.name;
l.visible = true;
subLayer = false;
else
l.visible = false;
subLayer = false;
else
l.visible = false;
subLayer = false;
popups.push(l);
else {
slides.push(l);
// hide all popups
var l = slides;
slides
.visible = i == j; log(depth, "setting " + slides
.name + " visibility = " + (i == j)); }
takeShots = false;
// hide all slides
// capture popups
var l = popups;
l.visible = true;
l.visible = false;
if (takeShots) {
if (files
.length < 2050) { files
.remove(); }
function log(depth, t) {
for (var j = 0; j < depth; j++)
$.write("----");
$.writeln(t);
