Expand my Community achievements bar.
SOLVED
Problems with Launch in IE 8.1
Avatar
Level 1
I'm facing problems with the implementation of Launch in my application. The library (.js file) report a generic error.
Adobe Launch supports IE 8.1? Can I try to make an adaptation on the .js file to workaround this problem?
Thank you.
1 Accepted Solution
Avatar
Correct answer by
Level 9
If you look at the your console in the browser, you should see a warning as the last line in the generated launch script is:
console.warn("Adobe Launch is unsupported in IE 9 and below.")
Using an IE lower than 10 is a risk to yourself and any other using it, you should really upgrade or tell your customer it is unsafe to use ancient browsers these days.
View solution in original post
1 Reply
Avatar
Correct answer by
Level 9
