Hi, everyone.
I am implementing motion blur by transform_world.
I am going to adjust level of motion blur between some values (for example: 0 ~ 100)
Is it possible? if so, how can I implement it?
Regards,
Anthonie.
perhaps this would also help:
transform_world does motion blur by spreading 16 instances between all
given matrices. if you provide 2 matrices you'll get 16 linear positions
between mat1 and mat 2.
if you provide 3 matrices, you'll get 8 from mat1 to mat2 and another 8
from mat 2 to mat3.
so providing more matrices won't give you more samples, but it will give
you a more "refined" look with rotations and curved paths.
On Fri, Oct 19, 2018 at 4:09 PM smarts19193560 <forums_noreply@adobe.com>
Hi Anthonie.
what do you mean by "adjust the level of motion blur"? i can think of a few
ways to interpret that:
1. the length of the blur. (i.e. shutter angle)
2. the number of samples in the blur.
3. the overall mix between the motion-blurred result and a non-motion
blurred render.
On Thu, Oct 18, 2018 at 10:50 AM smarts19193560 <forums_noreply@adobe.com>
Thank you for your replay.
Yes, Got it.
Actually I am implementing motion blur on Premiere Pro Transition not After Effect.
So, I used PF_TRANSFORM_WORLD on Premiere Pro because the function provides motion blur.
Is it possible to adjust level (quality) of motion blur by transform_world?
Regards,
Anthonie.
I increased MATRICES, but there is no difference.
Regards,
Anthonie.
from mat 2 to mat3.
Oh, OMG.
So, I need to make motion blur myself without transform world.
Thank you for your help.
Regards,
Anthonie.
if by "quality" you mean the number of samples used to create the blur,
then as far as i know transform_world always uses 16 samples.
perhaps if you set the overall quality flag of transform_world
to PF_Quality_LO, then some lower settings will be used for the motion blur
as well. i never used that transform_world with low quality settings so i
don't know for sure.
On Fri, Oct 19, 2018 at 4:01 PM smarts19193560 <forums_noreply@adobe.com>
