Have just installed AI CC 2019. In Preferences -> Type, the checkbox for 'Show Indic Options' is un-selectable. I can check and uncheck the 'Show East Asian Options' but not the Indic one.
System is Win 10 latest update - earlier this week.
Any suggestions / ideas?
Thanks and Cheers...
Bump....
Apologies for the 'Bump'... hate to do this but hoping it'll raise my problem above the radar and attract an answer...
I'm having the same problem...
New installation and Windows 10
Same problem in MacOS 10.14.1
I 'solved' this (mac) by
- uninstall InDesign through the supplied uninstaller, but keep preferences and settings.
- open the Creative Cloud app 'preferences'
- go to 'Apps' tab
- in Language select (in my case 'English [arabic script]'. (Is says 'English' on the left and has some Arabic script on the right, presumably saying 'Arabic' in Arabic.
Go back to the apps list and everything installed has changed its button from 'Open' to 'Install'. Install and all is well.
This is a ridiculous performance to go through and if necessary should be documented in the interface rather the not at all - and the official documentation just says to click the box for language, writing direction etc - not what to do if it is there but unresponsive.
SOLVED! on AI 2019 23.0.2 on OS 10.12.6 at least on my computer.
I had this problem, and was so pissed, just kept clicking (I know, stupid), then I noticed a 1 pixel blue line appear at the top of of the check box when I clicked at the very top edge of the box. I could "check" and "uncheck" even though the "check" was only the 1 pixel blue line, so I then I clicked [OK] after turning on the blue line. Then went back to the same window and the "Check" was, in fact, turned on. So I don't know if it will work for others or on other systems, but it worked for me. The moral of the story... sometimes wild, frustration-based clicking works! Hope this helps.
Sometimes clicking insanely does pay off! Thanks for this answer, because that is exactly what I did and it worked. I'm on macOS 10.14.4 and the UI just looks borked in those check boxes. They don't even look checked, but hey, as long as they work!
Thanks again, fellow spazzy clicker!
Amazing. I saw that subtle blue too at the very top of the box, but didn't think to try and click on it. Great discovery! Thanks.
this totally worked! which is ridiculous, but thank you!!!
Unbelievable! THANK YOU SO MUCH! Maybe we should report this issue to Adobe! You made my day!
Thanks it worked! you're a life saver!
Thanks to DTPublisher-Tampa, It works on mine too. -Windows10 machine-
This is exactly why I don't want to update any Adobe software now.
Thanks! Was having the same prob.
The Indic Option is neither highlighting to Blue nor it is selectable
It's there for me in the latest Illustrator CC 2019 version on a Mac. Try restoring your Illustrator preferences.
Thanks pal ive been trying since 2 days reinstalled the softaware but none of them helpedbut ur answer solved my issue. So thank you for this pal.
If you ordered online you might have gotten an European version that doesn't support that character set.
cool.
