2 Replies Latest reply on Oct 19, 2018 1:41 AM by morgani25374962
    Premiere Pro CC produce garbage image from mp4 input
    morgani25374962 Level 1
      Hello
      I Just recently downloaded the trial version of Premiere Pro CC to try it out with a project we have going on and i have a couple of video recordings that i have produced on one of our android tablets which is recorded in AVC .mp4 format and it playback just fine on my workstation PC but when i import it in Premiere and playback there i get a green mess in the previewer
      if i export it and play it back on the same PC i get this green mess aswell, so my question is can i do anything to make this right? i Have tried to reencode the source file with other apps to H264 and other formats which playback fine but still has this problem whenever i import them to Premiere.
      I was hoping to be able to use Premiere ofr my project but i'm not sure what to do here?
      I include here the info i got with mediainfo about the specs of the source file:
      Video
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : Baseline@L3.2
      Format settings                          : 1 Ref Frames
      Format settings, CABAC                   : No
      Format settings, RefFrames               : 1 frame
      Muxing mode                              : Container profile=High@1.3
      Codec ID                                 : avc1
      Codec ID/Info                            : Advanced Video Coding
      Duration                                 : 9 s 123 ms
      Source duration                          : 9 s 267 ms
      Bit rate                                 : 697 kb/s
      Width                                    : 720 pixels
      Height                                   : 1 152 pixels
      Display aspect ratio                     : 0.625
      Frame rate mode                          : Variable
      Frame rate                               : 9.496 FPS
      Minimum frame rate                       : 4.948 FPS
      Maximum frame rate                       : 62.718 FPS
      Standard                                 : NTSC
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.089
      Stream size                              : 780 KiB (83%)
      Source stream size                       : 795 KiB (84%)
      Title                                    : VideoHandle
      Language                                 : English
      Color range                              : Limited
      Color primaries                          : BT.601 PAL
      Transfer characteristics                 : BT.601
      Matrix coefficients                      : BT.601
      mdhd_Duration                            : 9123
      Codec configuration box                  : avcC
      Best Regards
      Mattias
