I have slider control Null with opacity control on several layers....linked together. Totally worked out before 16.0.
if i try to render via ME it is rendering all the layers at 100%
pleeeeease fix this annoying shit.
It‘s a Template for my customer! don’t See a workaround...
The expression engine was also my first thought. But the Legacy was on default!
A complete reinstall of Adobe Suite did the magic...
thx Rick!
PS: Don´t waste time on cleaning up the code. Move forward for more multithreading and GPU features instead RAM Preview for example
Are you using the Legacy Expression engine??? Probably not. Javascript is he default.
If you are we can't help without screenshots showing modified properties of the layers giving you problems and workflow details. As long as I use the legacy expression engine, the last tab in project settings, all of my animation presets and scripts seem to be working just fine. I did find a couple of problems with some of my projects using Javascript and I'm slowly going through them to clean up the code.
thx Rick!
