macOS High Sierra 10.13.6
Whenever I go to import a project and hit "Browse" to select a file, Flash Builder crashes and closes.
Console output below:
sh-3.2# ./Adobe\ Flash\ Builder\ 4.6
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Common/ChunkCompression.cpp:49: Error: unsupported compressor 8
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist'
org.eclipse.m2e.logback.configuration: The org.eclipse.m2e.logback.configuration bundle was activated before the state location was initialized. Will retry after the state location is initialized.
!SESSION 2018-10-19 09:27:40.339 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -keyring /var/root/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -keyring /var/root/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2018-10-19 09:27:44.340
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
org.eclipse.m2e.logback.configuration: Logback config file: /private/var/root/Documents/Adobe Flash Builder 4.6/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.0.0.20110607-2117.xml
org.eclipse.m2e.logback.configuration: Initializing logback
org.eclipse.m2e.logback.configuration: eclipse.consoleLog=true
!ENTRY org.eclipse.ui 2 0 2018-10-19 09:27:44.748
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2018-10-19 09:27:44.748
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY com.adobe.flexbuilder.project 4 43 2018-10-19 09:27:46.307
!MESSAGE Avoiding non-existent source container src while figuring out files to copy to output folder.
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.project.compiler.internal.BuilderUtils.copyDependents(BuilderUtils.java:494)
at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuilder.java:425)
at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncrementalBuilder.java:187)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!ENTRY org.eclipse.core.net 1 0 2018-10-19 09:27:46.378
!MESSAGE System property http.proxyHost has been set to 127.0.0.1 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.core.net 1 0 2018-10-19 09:27:46.379
!MESSAGE System property http.proxyPort has been set to 8888 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.core.net 1 0 2018-10-19 09:27:46.380
!MESSAGE System property https.proxyHost has been set to 127.0.0.1 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.core.net 1 0 2018-10-19 09:27:46.381
!MESSAGE System property https.proxyPort has been set to 8888 by an external source. This value will be overwritten using the values from the preferences
!ENTRY com.adobe.flexbuilder.ui 4 1 2018-10-19 09:27:47.953
!MESSAGE Product = null version = 460 edition = php_prem
!ENTRY org.eclipse.jface 2 0 2018-10-19 09:27:48.533
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2018-10-19 09:27:48.533
!MESSAGE A conflict occurred for COMMAND+SHIFT+F12:
Binding(COMMAND+SHIFT+F12,
ParameterizedCommand(Command(org.eclipse.mylyn.tasks.ui.command.searchForTask,Search Repository for Task,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.mylyn.internal.tasks.ui.search.SearchTaskHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(com.adobe.flexbuilder.flashbridge.export.publish.movie,Publish Movie,
Publish in Flash Professional,
Category(com.adobe.flexbuilder.flashbridge.flashProCommands,&Flash Professional,null,true),
,,true),null),
org.eclipse.ui.contexts.window,,cocoa,system)
java.lang.ClassCastException: org.apache.commons.httpclient.DefaultMethodRetryHandler cannot be cast to org.apache.commons.httpclient.HttpMethodRetryHandler
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:427)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at com.adobe.flexbuilder.editors.derived.ui.startpage.StartPageXMLReader.getSourceFromURL(StartPageXMLReader.java:192)
at com.adobe.flexbuilder.editors.derived.ui.startpage.StartPageXMLReader.readStartPageConfiguration(StartPageXMLReader.java:149)
at com.adobe.flexbuilder.ui.StartPage.init(StartPage.java:197)
at com.adobe.flexbuilder.ui.StartPage.access$0(StartPage.java:196)
at com.adobe.flexbuilder.ui.StartPage$1.run(StartPage.java:102)
[Fatal Error] :1:1: Premature end of file.
org.eclipse.core.runtime.CoreException: Could not read XML document
at com.adobe.flexbuilder.project.internal.FlexProjectCore.createCoreException(FlexProjectCore.java:990)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:213)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:180)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:275)
at com.adobe.flexbuilder.project.fxp.ProjectImportUtility.getOutputFolderValue(ProjectImportUtility.java:214)
at com.adobe.flexbuilder.project.fxp.ProjectImportUtility.extractPathVariables(ProjectImportUtility.java:354)
at com.adobe.flexbuilder.exportimport.importwizard.FolderProjectImporter.retrievePathVariables(FolderProjectImporter.java:209)
at com.adobe.flexbuilder.exportimport.importwizard.FolderProjectImporter.<init>(FolderProjectImporter.java:60)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage.createProjectImporter(ImportWizardPage.java:554)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage.fileRadioSelected(ImportWizardPage.java:193)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage.access$2(ImportWizardPage.java:190)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage$3.widgetSelected(ImportWizardPage.java:250)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.adobe.flexbuilder.exportimport.menuactions.FlexProjectImportAction.run(FlexProjectImportAction.java:52)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.xml.sax.SAXParseException: Premature end of file.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:247)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:287)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:211)
... 55 more
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage.folderRadioSelected(ImportWizardPage.java:214)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage.access$3(ImportWizardPage.java:210)
at com.adobe.flexbuilder.exportimport.importwizard.ImportWizardPage$4.widgetSelected(ImportWizardPage.java:270)
... 54 more
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/PrivateFrameworks/FinderKit.framework/Resources/Base.lproj/AppCentricFinderView.nib'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/PrivateFrameworks/FinderKit.framework/Resources/Base.lproj/SidebarView.nib'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Common/ChunkCompression.cpp:49: Error: unsupported compressor 7
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/PrivateFrameworks/FinderKit.framework/Resources/Base.lproj/ColumnView.nib'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.60.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/PrivateFrameworks/FinderKit.framework/Resources/Base.lproj/ArrangeByMenu.nib'
Invalid memory access of location 0xff000010 eip=0x4c540d81
Segmentation fault: 11
