1 Reply Latest reply on Jan 28, 2008 12:02 AM by Ivascu Cristian
    Import project failed at basic UI level
    yoav@cyteam.com
      An interesting occurance, got the FB into a situation where trying to use Import Flex Project didn't bring up the Wizard/Dialog window. After Exit & and re-start of the FB3 the import project function worked again.
      Noticed the associated error log ( below) :
      !ENTRY org.eclipse.ui 4 0 2008-01-24 15:27:00.031
      !MESSAGE Unhandled event loop exception
      !STACK 0
      java.lang.IllegalArgumentException: Argument not valid
      at org.eclipse.swt.SWT.error(SWT.java:3547)
      at org.eclipse.swt.SWT.error(SWT.java:3481)
      at org.eclipse.swt.SWT.error(SWT.java:3452)
      at org.eclipse.swt.widgets.Widget.error(Widget.java:432)
      at org.eclipse.swt.widgets.Label.setImage(Label.java:326)
      at org.eclipse.jface.dialogs.TitleAreaDialog.showMessage(TitleAreaDialog.java:534)
      at org.eclipse.jface.dialogs.TitleAreaDialog.setMessage(TitleAreaDialog.java:510)
      at org.eclipse.jface.wizard.WizardDialog.updateMessage(WizardDialog.java:1291)
      at org.eclipse.jface.wizard.WizardDialog.updateTitleBar(WizardDialog.java:1396)
      at org.eclipse.jface.wizard.WizardDialog.update(WizardDialog.java:1232)
      at org.eclipse.jface.wizard.WizardDialog.showStartingPage(WizardDialog.java:1191)
      at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:545)
      at org.eclipse.jface.window.Window.create(Window.java:426)
      at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1081)
      at org.eclipse.jface.window.Window.open(Window.java:785)
      at com.adobe.flexbuilder.standalone.actions.FlexProjectImportAction.run(FlexProjectImportAct ion.java:18)
      at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:546)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :402)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :112)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
