2 Replies Latest reply on Oct 22, 2018 2:31 AM by vic65
    Problems with variable frame rate iPhone footage in Premiere 12.1
    vic65
      Hi, I've had problems editing my iPhone 7 footage in Premiere 12.1 - which should have fixed the issues with variable frame rate. It does recognise it as VFR in the clip properties, and most of the clips play fine - but a couple (which are using the exact same settings as the rest of the footage, shot just before clips that play fine) will stutter, or the audio will just cut out after a few seconds (it plays ok in Quicktime etc). You can even see the waveforms in the sequence, but it plays silently. I've tried re-importing the clips, and deleting the Media Cache Files, which didn't help. If I convert those problematic clips to ProRes 24fps, they then work fine. Can anyone give any advice about why this might be happening?
