Hello, in my document I have one circular frame on each page. I am loading one eps file into each of the circular frames via a merge - there are a few thousand images. When an image is loaded into the frame, if the image is a square or it shows up fine, but if the image is tall or wide, then it doesn't effectively fill up the space in the circle frame. I'm looking for a script or suggestions on where to start that essentially something that does the following for each of the frame in the document. I'm pretty new to the scripting.
if image.width > image.height then
frame.width = x
frame.width = y
endif
if image.height > image.width then
frame.width = a
frame.width = b
endif
fit image proportionally in frame
Have something to add?
