22 Replies Latest reply on Jan 3, 2019 3:24 PM by joaogdesigner
    Brackets extensions on Dreamweaver?
    joaogdesigner Level 1
      Inside the Dreamweaver's user preferences folder (C:\Users\User\AppData\Roaming\Adobe\Dreamweaver CC 2019\en_US\Configuration), now there is a folder called "Brackets" and inside of it there are the same structure of the default Brackets' default installation folder. Does it that mean I can now use Brackets features inside Dreamweaver? If I copy all my Brackets extensions and paste into that "Brackets" folder inside Dreamweaver's user configuration (appdata), will I able to use those extensions in some way?
      This is the full path for the folder I'm talking about (Dreamweaver CC 2019):
      • Main folder: C:\Users\Joao\AppData\Roaming\Adobe\Dreamweaver CC 2019\en_US\Configuration\Brackets
      • Extensions folder: C:\Users\Joao\AppData\Roaming\Adobe\Dreamweaver CC 2019\en_US\Configuration\Brackets\extensions
      • Extensions subfolders:
        • C:\Users\WinUser\AppData\Roaming\Adobe\Dreamweaver CC 2019\en_US\Configuration\Brackets\extensions\disabled
        • C:\Users\WinUser\AppData\Roaming\Adobe\Dreamweaver CC 2019\en_US\Configuration\Brackets\extensions\user
      If you use Brackets, you already know its extensions are kept inside \Brackets\extensions\user .
      I've just got a little bit confused with that folder there and what its function within DW.
      Note: I'm on Windows 10 (1803 build).
