2 Replies Latest reply on Oct 29, 2018 2:08 AM by davek95716539
    MP3 START & STOP CUT OFF
    davek95716539 Level 1
      Running AMS 5.1, Audio MP3's only No Video
      1. MP3 START/STOP CUT OFF
        with a playlist of MP3s of different lengths (time), it is currently starting each one, playing it, then stopping and starting the next one and creating "what seems" is a new stream each time to the players, if this is so, can it be adjusted to make it one continuous stream?
      2. TWO STREAMS TO ONE
        currently have two streams that go to the player, one is mp3s playing, the other is microphone - this works great for a flash player, but no good when trying to use for other devices as they only can take one stream - how can these be combined?
        • 1. Re: MP3 START & STOP CUT OFF
          Graeme Bull Adobe Community Professional
          1. It depends a lot on the mp3 files on if they have the same bitrate and encoding.  Mostly though if you are using a server side NetStream then it should just be one stream that you play from the client side.
          2. You play it with server side NetStream and then play that on the client side.
          • 2. Re: MP3 START & STOP CUT OFF
            thank you great info
            this is the log on what is happening
            application.onConnect, clientObj.clientType: radio
            Mon Oct 29 2018 09:00:44 GMT+0000 (GMT Standard Time)
            *** Stream dj1 --- NetStream.Play.Stop
            application.name: RadioDispatcher/126
            currentNode.attributes.radio: 126
            application.radio: 126
            Now playing: Songs/G-Easy and Halsey/2018/Single/c8713d57f5f19fb4e81f93d7ae6101af3c15056494f04d9136792b6b5c105c12
            application.host: https://www.xxxx.com
            song counted: 1009309 radio: 126 success: true
            *** Stream dj1 --- NetStream.Unpublish.Success
            *** Stream dj1 --- NetStream.Publish.Start
            *** Stream dj1 --- NetStream.Play.Reset
            *** Stream dj1 --- NetStream.Play.Start
            *** Stream dj1 --- NetStream.Data.Start
            Now playing: Songs/The Prince Karma/2018/Single Minsk/816365c6f734790a49c4273807848c61ad64d2cfc933b913e1916a2bb756c6a5
            song counted: 1014300 radio: 126 success: true
