• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
9
Can't get AE file to the Media Encoder Queue
Community Beginner ,
Oct 20, 2018 Oct 20, 2018
Yesterday I updated AE and Media Encoder to the latest versions and after that I'm not able to get the AE file to the queue in Media Encoder.
I press;
Export - Add to Adobe Media Encoder Queue: But the file doesn't show up in the queue window in Media Encoder.
I've tried to reinstall earlier versions but then the quality of the movie gets really really bad!
I use a MacBook Pro 15 and I have Adobe Creative Cloud
Best regards
Johnny
TOPICS
Error or problem , Export or render
Views
68.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Nov 04, 2018 Nov 04, 2018
This could be caused by mismatch languages between OS and AE/AME.  For an experiment, could you try switching OS language to the language set for AE/AME  to see if this helps?
Votes
Translate
Translate
Community Expert ,
For now, open Media Encoder and go to File > Add After Effects Composition and add the project file manually and then select the comp/comps you want to export.
As of now i don´t have another solution.
Votes
Translate
Translate
Report
Report
I’ve tried to do that but the connection to the Dynamic Link-server fails every time.
Votes
Translate
Translate
Report
Report
Community Expert ,
If you create a brand new project in AE CC2019 and just place let´s say a Solid in the comp with no effects on it, can you export that through Media Encoder CC2019?
Votes
Translate
Translate
Report
Report
No 😕
Still nothing. I’ve tried to export from AE to AME and I’ve also tried to import the composition in AME, but neither one works.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 21, 2018 Oct 21, 2018
I found this thread that has a solution. It is probably solved by now but worth checking: AME cannot connect to Dynamic Link Server
If that dont do the trick, try to use the Creative Cloud Cleaner Tool: Use the Creative Cloud Cleaner Tool to solve installation problems
Votes
Translate
Translate
Report
Report
Apr 30, 2020 Apr 30, 2020
This doesn't work for me. I tries to connect to the dynamic link server after that it says that the file cannot be openend.
Votes
Translate
Translate
Report
Report
I have exactly the same problem
Votes
Translate
Translate
Report
Report
New Here ,
Apr 18, 2020 Apr 18, 2020
Same problem
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 22, 2018 Oct 22, 2018
What's your platform? Mac or Win?
If Mac, can you open terminal and run the following command?
       ls -l /Applications | grep Adobe
Then copy the output here. Thanks in Advance.
Votes
Translate
Translate
Report
Report
Oct 23, 2018 Oct 23, 2018
I have the same problem.. After updating Media Encoder is dead
Votes
Translate
Translate
Report
Report
New Here ,
Oct 24, 2018 Oct 24, 2018
The same problem, I running on Mac pro (macos high sierra).
After I updated both AE and Media encoder, I can't export AE to Media encoder, there's nothing get into the queue.
I try manual but can't link to dynamic link server. It takes a long time and nothing happen.
I tried the clean tool, reinstalled all my adobe app last night, but both didn't work.
Votes
Translate
Translate
Report
Report
I got helped by the help center. But I’m using the older versions now on both AE and AME. Can’t get the new versions to work.
Thanks so much for all your help!
Votes
Translate
Translate
Report
Report
New Here ,
Oct 25, 2018 Oct 25, 2018
I also got the problem on mac (version 10.13.6 High Sierra).
my specs are:
iMac (Retina 5K, 27-inch, Late 2015)
3,3 GHz Intel Core i5
32 GB 1867 MHz DDR3
AMD Radeon R9 M395 2048 MB
ls -l /Applications | grep Adobe output:
drwxrwxr-x   6 root       admin     204 23 okt 09:50 Adobe
drwxrwxr-x@  6 root       wheel     204 24 okt 07:36 Adobe Acrobat DC
drwxrwxr-x   3 root       wheel     102  4 okt 15:01 Adobe Acrobat Reader 2017.app
drwxrwxr-x   7 root       admin     238 23 okt 09:51 Adobe Acrobat XI Pro
drwxrwxr-x  10 root       admin     340 23 okt 09:51 Adobe After Effects CC 2015
drwxrwxr-x   3 root       admin     102 23 okt 09:48 Adobe After Effects CC 2017
drwxr-xr-x  11 root       admin     374 23 okt 09:51 Adobe After Effects CC 2018
drwxrwxr-x@ 11 root       admin     374 25 okt 09:50 Adobe After Effects CC 2019
drwxr-xr-x@ 13 root       admin     442 23 okt 14:27 Adobe Animate CC 2019
drwxrwxr-x   5 root       admin     170 23 okt 09:51 Adobe Audition CC 2017
drwxr-xr-x   9 root       admin     306 23 okt 09:51 Adobe Bridge CC 2018
drwxrwxr-x@  9 root       admin     306 23 okt 10:17 Adobe Bridge CC 2019
drwxrwxr-x   8 root       admin     272 23 okt 09:50 Adobe Bridge CS6
drwxrwxr-x   4 root       admin     136 23 okt 09:50 Adobe Character Animator (Preview)
drwxrwxr-x   5 root       admin     170 23 okt 09:49 Adobe Character Animator CC (Beta)
drwxr-xr-x   6 root       admin     204 23 okt 09:50 Adobe Creative Cloud
drwxr-xr-x@  3 root       wheel     102  3 mrt  2016 Adobe DNG Converter.app
drwxr-xr-x   4 root       wheel     136  3 mrt  2016 Adobe Digital Editions 4.5.app
lrwxr-xr-x   1 root       admin      44 10 dec  2015 Adobe Digital Editions.app -> /Applications/Adobe Digital Editions 4.5.app
drwxrwxr-x  11 root       admin     374 23 okt 09:50 Adobe Dreamweaver CC 2018
drwxr-xr-x@ 10 root       admin     340 23 okt 15:42 Adobe Dreamweaver CC 2019
drwxrwxr-x  10 root       admin     340 23 okt 09:51 Adobe Dreamweaver CS6
drwxrwxr-x   5 root       admin     170 23 okt 09:51 Adobe Edge Animate CC 2015
drwxrwxr-x   8 root       admin     272 23 okt 09:50 Adobe ExtendScript Toolkit CC
drwxrwxr-x   7 root       admin     238 23 okt 09:50 Adobe Extension Manager CC
drwxrwxr-x   6 root       admin     204 23 okt 09:50 Adobe Extension Manager CS6
drwxrwxr-x  10 root       admin     340 23 okt 09:50 Adobe Fireworks CS6
drwxrwxr-x  12 root       admin     408 23 okt 09:51 Adobe Flash CS6
drwxrwxr-x   3 root       admin     102 23 okt 09:51 Adobe Illustrator CC 2015.3
drwxrwxr-x  14 root       admin     476 23 okt 09:51 Adobe Illustrator CC 2017
drwxrwxr-x  14 root       admin     476 23 okt 09:51 Adobe Illustrator CC 2018
drwxrwxr-x  12 root       admin     408 23 okt 09:51 Adobe Illustrator CS6
drwxrwxr-x   3 root       admin     102 23 okt 09:50 Adobe InDesign CC 2014
drwxrwxr-x  15 root       admin     510 23 okt 09:50 Adobe InDesign CC 2015
drwxrwxr-x  15 root       admin     510 23 okt 09:51 Adobe InDesign CC 2017
drwxrwxr-x  13 root       admin     442 23 okt 09:51 Adobe InDesign CS6
drwxrwxr-x   5 root       admin     170 23 okt 09:51 Adobe Lightroom CC
drwxrwxr-x@  5 root       admin     170 25 okt 09:43 Adobe Media Encoder CC 2019
drwxrwxr-x   6 root       admin     204 25 okt 09:58 Adobe Media Encoder CS6
drwxr-xr-x   6 root       admin     204 23 okt 09:50 Adobe Muse CC 2018
drwxrwxr-x   4 root       admin     136 23 okt 09:48 Adobe Photoshop CC 2015
drwxrwxr-x   4 root       admin     136 23 okt 09:50 Adobe Photoshop CC 2015.5
drwxrwxr-x   4 root       admin     136 23 okt 09:50 Adobe Photoshop CC 2017
drwxrwxr-x  10 root       admin     340 23 okt 09:51 Adobe Photoshop CC 2018
drwxr-xr-x@ 10 root       wheel     340 23 okt 15:43 Adobe Photoshop CC 2019
drwxrwxr-x  12 root       admin     408 23 okt 09:50 Adobe Photoshop CS6
drwxr-xr-x   6 root       admin     204 23 okt 09:50 Adobe Premiere Pro CC 2018
Votes
Translate
Translate
Report
Report
I have the same problem since the update. Media Encoder does not work with AE. Have tested all suggestions for solutions.
Macbook Pro 2.4 Intel Core 5i
Votes
Translate
Translate
Report
Report
Oct 26, 2018 Oct 26, 2018
I am having the same issue. This is really frustrating because it is holding up my production. Adobe needs to get a fix out ASAP. This is unsatisfactory
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 29, 2018 Oct 29, 2018
When AE is running, do you see "dynamiclinkmanager" running in Activity Monitor?
If you create a new user in your system, switch to that new user and run AE, does this help?
Votes
Translate
Translate
Report
Report
New Here ,
Dynamiclinkmanager is running with AE.
Also media encoder is taking a long time to que a comp if I drag a comp in.
I cant test the new user
Votes
Translate
Translate
Report
Report
Oct 30, 2018 Oct 30, 2018
Yes, Dynamiclinkmanager is running with AE.
I just can't create new user on my Mac just like that.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Are you not Admin on the Mac?
Is it a company Mac managed by IT?
Votes
Translate
Translate
Report
Report
Oct 31, 2018 Oct 31, 2018
dynamiclinkmanager running here as well. My Media Encoder won't que anything no matter what way I try to. And when I quit it I get a fail message.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Could you post the screenshot of the fail message you are seeing?  Are you Admin on your system? Or standard user?
Also, could you tell me your license type, e.g. regular monthly/yearly subscription, enterprise license, team license and etc?
Votes
Translate
Translate
Report
Report
Explorer ,
I have been having issues with AME/DynamicLink from both Premiere and After Effects on both work and home setups (enterprise licence / individual yearly, respectively).
Takes a full 2-3 minutes just to get a sequence/comp across DynamicLink to AME, then half the time when I run AME it returns 'failed' status anyway.
For now I'm just having to render the old way, in-program.
Frustrating.
Votes
Translate
Translate
Report
Report
Nov 01, 2018 Nov 01, 2018
Hey! There is no error message, it just happens .... nothing. Media encoder starts but then nothing happens. Nothing.
I'm Admin on Macbook Pro 2.4 Intel Core i5. Regular monthly on CC.
Everything worked perfectly until the last update ...
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Could you try the following?
- In AE's Help menu > Sign Out.  Then, from Creative Cloud desktop app, log back in.
- After rebooting the system, while holding shift key down, launch AME first (this uses dynamiclinkmanager from AME and clears its prefs)
- Instead of using Files > Export > "Add to Adobe Media Encoder Queue", try "Add to Render Queue", then click "Queue to AME"
If any of those helps, you may want to try
User and license information issues | CC 2019
Votes
Translate
Translate
Report
Report
