So I found a V-CAM source, I am now using it and quite happy however, is it possible to untoggled bitmap when the objects that are bitmapped are viewed by the cam? For instance, lets say I have a vector movieclip with a bunch of vector art, I toggle export as bitmap on the movieclip from my IDE, now would it be possible to add on to my VCAM, that everything in its view (it resizes stage) untoggles or redraws back to vector, while the rest of map/movieclip is still in bitmap? And as the VCAM moves away, what was shifted from bitmap to vector gets shifted back to bitmap?
var camColor: ColorTransform = new ColorTransform();
var parentColor: ColorTransform = new ColorTransform();
var cX: Number;
var cY: Number;
var sX: Number;
var sY: Number;
this.visible = false;
var oldMode: String = stage.scaleMode;
stage.scaleMode = StageScaleMode.EXACT_FIT;
cX = stage.stageWidth / 2;
cY = stage.stageHeight / 2;
sX = stage.stageWidth;
sY = stage.stageHeight;
stage.scaleMode = oldMode;
camColor = this.transform.colorTransform;
parentColor = this.parent.transform.colorTransform;
camControl(new Event(Event.ENTER_FRAME));
addEventListener(Event.ENTER_FRAME, camControl);
addEventListener(Event.REMOVED, resetStage);
function camControl(event: Event): void {
parent.transform.colorTransform = camColor;
var xScale: Number = sX / this.width;
var yScale: Number = sY / this.height;
parent.x = cX - (this.x * xScale);
parent.y = cY - (this.y * yScale);
parent.scaleX = xScale;
parent.scaleY = yScale;
function resetStage(event: Event): void {
removeEventListener(Event.ENTER_FRAME, camControl);
parent.transform.colorTransform = parentColor;
parent.scaleX = 1;
parent.scaleY = 1;
parent.x = 0;
parent.y = 0;
Why not just use the camera built into Animate now?
what do you mean by VCam sources?
The code that I gave preview to. It simply redraws stage.
How do you control it from code?
